Okay, My Network TV is coming in again - I figured out the issue.
Not sure if I should post this in a new thread, but I will outline the issue.
The weather has been good, so I wanted to dial in the 621-2 some more, for both C and Ku. I used a 6 foot run of coax from the LNBF to the receiver. (Took the TV and receiver outside)
I got it dialed in on 99W to received both C and Ku in the high 90's on the Coolsat. Got ABC, CBS, CW, FOX, My TV, even got E on Ku as it was coming in.
Then I brought the box back inside, hooked it up, and most of the channels dropped off. All I can get is the E, CBS Newsfeed and I get high signal on the various ABC and GDMX channels. But all ther other dropped in the red below 10 and won't come in.
Is it possible that the LNBF was tuned only for the short run, and needs to be adjusted for a longer run? (I know that doesn't make sense. Thought I would ask)
Anyhow, not sure what the deal is. The run is only about 100ft and I have got C channels in the past. - In the Dish Settings, the LNB power is on for C, and as I mentinoned, everything is perfect right off the dish.
Do I need an amplifier or something? I am still failry new to FTA and have been playing with it on and off for the past few months, but I was able to pick up C channels before.
