Question about the 522...
Pyrophoric
71
First, is there a way to set it so that when in single mode it will always record on the tuner you want? I want to settings and set it to tuner 2 as the primary but it still doesnt matter ... it just picks which one it wants even if it doesnt make sense.
Also, I am thinking about turning it the 522 back to dual mode so I can record 2-3 shows while watching a 4th but I wanted to know if there are many bugs doing that and if it can even be done. I was planning on hooking up both tuners to the same tv. Can those things be done?
Thx :)
Per time slot you can only record 2 shows. Doesn't matter if the 522 is in single mode or dual mode. The most you can do in single mode is record 2 programs and watch a third previously recorded show. In Dual Mode you could record 2 shows and watch 2 seperate previously recorded shows on 2 seperate tvs. That's it.
Help for cabling indoor installation
Cannot change channel - Bug or Feature?
