I want to program my Motorola remote to operate both a 922 and a 920 as separate units.
I have tried following the instructions that came with the remote to use the AUX to program a code in for a 920. That did not work.
I tried following the instructions in the 922 manual about programming the remote in the AUX mode for the 920, but that did not work either.
Of course, the remote will work on both receivers through the SAT mode, but one problem....I am using both receivers in my living room. The IR is used for the 920 and the UHF is used on the 922. Each receiver has its own separate 8 foot mesh dish.
I just do not want to have to take the antenna off the 922 every time I want to sit in my living room and use the 920. Nor do I want to have to block/cover up the remote sensor on the 922 if I were to remove the 922's antenna.
I also watch tv upstairs and use the UHF on the 922 to watch programs.
I have the 922 hooked up using only a c-band lnb, and I want to use a c/ku lnb on the 920. So having one remote with two separate codes for operating these two receivers would be awesome.
Football season is coming up and I would like to search out the wild feeds and backhauls, etc. on the 920.
So...has anyone been able to program the remote to handle two DSRs? Any suggestions will be appreciated.
