We just got a new roof, and the installers had to remove our dishes. I have an appointment scheduled to reinstall the dishes on Tuesday. Unfortunately, I just found out that the Emmy Awards are being broadcast tomorrow. Recording them is an import thing to do in our house. So I have about 24 hours to come up with a solution
My setup is old. I have a 722k, a dish 500 and another dish with only 1 lnb, which I guess makes it a dish 300?
the LNB on the dish 300 says it is a dish pro. the installation had one 1 cable from the dish 300 to the dish 500, and 2 cables from the dish 500 to the 722k. the 500 was pointed at 110 and 119, and the 300 was at 121
I was able to access the dish 300 and disconnect it. The dish 500 is significantly harder to get to. I mounted it on a makeshift stand, put it out in the driveway, ran a single line from it back to my 722k, aligned it to 110 and was able to get a pretty good signal. I am able to watch any of the shows that are on 110, which includes our local Fox station, so we will be able to watch the Emmy Awards. Yea!
However, the program guide will not download. I currently can see about 2 hours out, then "No Info Available" for about a day and a half, then nothing. If I try to go past this, I get a dialog stating that the program information is outdated and offers to retrieve program information now. If I select yes, it will try for about 10-15 minutes, then stop and I still do not have a program guide.
No big deal, except that it seem I can not record without the program guide.
I have reset the 722k by unplugging it. I have run check switch a few times.
check switch reports that only port 2 on Satellite Input 1 is "OK",
It also states this is a DPP Twin w/Separator, so does that mean dish pro plus?
Still not program guide and therefore no recording and therefor I am in trouble
Questions
Is it even possible to get the complete program guide from only 110 or do I need to see 119 as well?
Or is the problem that I only have one cable run?
I really don't want to try to climb up on the roof, get the LNB that can see both 110 and 119 if I don't have to.
Questions
