Prof 7301, 7500 and 8000 Tuners
It's possible you have a hardware problem with regard to S2, but I would look first elsewhere. I have 5 Profs running on Linux (3 x 7301 and 2 x 7500) and 2 on Windows XP (1 x 7301 and 1 x 8000). I've subjected a considerable amount of S2 to all of them, and during last year's Galaxy 15 festival some of them ran 24 x 7 for several weeks on the high SR S2 transponders without incident. So I can attest there is no systemic heat or other problem related to S2 use.
I can't say much specifically on AltDVB - I tried it out in 2009, didn't like it and haven't bothered with it since. I do use DVB Dream 1.4i and have tested several of the 1.5 versions. The 1.5 versions contain some wicked bugs in the processing of certain transport streams, and I finally had to give up on them. So I've been using the 1.4i version without serious issue for longer than I can remember. It has a few problems and limitations, but nothing I cannot work around, and it has always been my Windows workhorse. My two copies of DVB Dream run continuously without intervention for months, however as they are only a front-end to my multimedia server, they perform no rendering and all codecs are disabled on that machine. That is probably different from the way most people run their FTA PCs.
@Pendragon
I would like to install Prof 7500 on XP SP3 (momentary installed Microsoft Visual C++ 2005 and Microsoft Framework 2.0, Windows Media Player 11, Mainconcept Decoder Pro, DirextX 9.0c, Acrobat Reader X, I`m not sure I need or not upgrade to Microsoft Framework 3.5 Family and Microsoft Visual C++ 2010...as I know one "little" detail can make problems.... with Windows.... and usb receiver... and now I`m not sure what I need to do...), as I can read this and Rick`s forum I`m too too much confused. Please tell me what I need to do for properly installation, step by step. As you said DVB Dream 1.4i is better and I respect you and will try that. But I dont know about drivers and bda module differencies, what I need to install and which version. Someone else tell me it is latest driver but someone it is some other.
Drivers for Prof Revolution S2 7500 USB | proftuners.com
Index of /download/beta
Index of /download/drivers_prof
Your experience, and knowledge, is great and you know after all the best. Thank you beforehand for help. Still my Prof 7500 is not arrived to home, 6th day, and I would like to prevent nervous days with crashes and other problems on Acer Aspire One D150, especially with stability and DVB-S2 reception. Maybe Smart DVB is better, but I love too much DVB Dream and must be my first choice for beginning with new USB receiver. Untill now I tried Skystar PCI 2.6B, Skystar USB Plus Box, Skystar USB 2 and Skystar HD2.
Thank you again and best regards
Sorry Edoh, I've been out of town for several days and haven't had time to check on forums. The only PC tuners I run on Windows at the moment are the Prof 7301 and 8000. However I did use a 7500 on XP(SP3) for several months and it worked fine. That was up until about a year ago, so i can only vouch for the latest driver for that time period. If you run DVB Dream 1.4i with a Prof tuner and want to use DiSEqC and/or USALS, you will also need their version of the bda.dev module. I can't find it anywhere on their new website, although they do have an image that shows a URL that redirects to the AdvanceTune site where you can find the software:
I didn't try it, but for the 7500 it appears the file you want is at:
http://www.prof-tuners.com/download/soft_prof/dvbdream/bda_advancetune.dev
thank you for answer, never mind when important is it happened
maybe your driver was Prof7500_Driver_1.0.1.2_W32 (from 5.6.2009) ? i found it on proftuners.com
i`m afraid to try wrong (with bad results i mean) driver, maybe newest version Prof7500_Driver_2.0.0.2_XP32 is not better and is buggy.....
else i dont need diseqx or usals because i have inverto twin ultra lnb and one coax. attached to opticum 7100c (for my long experience most reliable receiver for moving strong 2100 diseqc1.2 rotor) and other coax. cable will be attached to prof 7500 (still not arrived, if not arrive tomorrow i must wait 4.5.:( because 1.,2. and 3.5 not working days :(, i hate wait too long, from 20.04.)....because from that days trying to be utilized for prof 7500....too long for me....pih....
  • Prof7500_Driver_1.0.1.2_W32.zip
Has anyone tried the new Prof 7301 Beta! Driver for Win7 (64 bit, PTG Engine) 2.1.0.0 that was post on ProfTuners website yesterday? Or know what's new with these drivers?
I see there's also a 32 bit version posted as well.
rrob311 said:
Do these tuners support 4:2:2? Blind scan?
4:2:2 is supported by software not hardware. there is also 3rd party blindscan software called crazy scan that supports the prof hardware.
crackt out,.
hiwhen i want install prof 7301 driver on windows 7 64 bit blue screen come and i cant install prof diiver what i should do?
thanks and sorry for my bad english
Here''s a link I found with google:http://proftuners.com/driver7301.html
The last one on the list says win7 64bit, if you haven't already tried that one....
*The driver file is compressed, you are "unzipping" the ZIP file, correct? If not, download 7-Zip , I think its still free, and unzip the file before loading. Beyond that, hopefully somebody else will come along with more information. &&&Welcome to Satelliteguys!!
nmtu have you looked at any of the linux distributions for an alternative? I'd suggest Debian linux first, for the vast repositories of software. If you don't want to try installing linux ( it's really easy and you can dual-boot Windows), you could go for one of the Live-CD versions like Puppy Linux that don't install to the HD but run live in memory. You can even find/download DVB software, and it will store in a "save-file" on the windows partition, without harming anything. Just a thought, since something seems to be broken with your 64bit driver install in Windows.
thanks turbosat
actually i have dualboot ubuntu 12.04 64bit and windows 7 64 bit and dvb works fine on both but when i remooved my another card(technotrend s2-3200) from system and replace prof's slot ubuntu and windows can't detect card
i tried to install drivers in windows but it gives blue screen error till i can install drivers but dvb not work properly and don't have signal
in ubuntu when i run lspci the dvb card shown but in dev folder i don't have dvb folder is there any tuturial to install prof 7301 driver on ubuntu?
thanks in advance
If you dont see it in /dev/dvb then its not registered. 12.04 should come with everything built in that you need to get up and running. I would recommend my repo but thats something you can try later if you want, it enables some more features of the 7301 like blind search, IQ plot and spectrum scan.
You can find my repository at https://bitbucket.org/updatelee/s2-liplianin-v37-udl
dmesg should show you if the card is attempting to register and failing for some reason. can you post the output of lspci ?
UDL
thank you updatelee
this is lspci output:
Code:
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03)
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.1 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 2
00:1c.2 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 3
00:1c.3 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 4
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIB (ICH10) LPC Interface Controller
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller #1
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller #2
01:00.0 Multimedia video controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder (rev 05)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
03:00.0 IDE interface: JMicron Technology Corp. JMB368 IDE controller
08:00.0 VGA compatible controller: NVIDIA Corporation G92 [GeForce GTS 250] (rev a2)
and this is dmesg output:
Code:
[    0.478027] pcieport 0000:00:1c.5: setting latency timer to 64
[    0.478062] pcieport 0000:00:1c.5: irq 45 for MSI/MSI-X
[    0.478155] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    0.478158] pci 0000:08:00.0: Signaling PME through PCIe PME interrupt
[    0.478161] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[    0.478179] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[    0.478183] pcie_pme 0000:00:1c.0:pcie01: service driver pcie_pme loaded
[    0.478199] pcieport 0000:00:1c.1: Signaling PME through PCIe PME interrupt
[    0.478203] pcie_pme 0000:00:1c.1:pcie01: service driver pcie_pme loaded
[    0.478219] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
[    0.478223] pcie_pme 0000:00:1c.2:pcie01: service driver pcie_pme loaded
[    0.478240] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
[    0.478242] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[    0.478246] pcie_pme 0000:00:1c.3:pcie01: service driver pcie_pme loaded
[    0.478262] pcieport 0000:00:1c.5: Signaling PME through PCIe PME interrupt
[    0.478264] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    0.478268] pcie_pme 0000:00:1c.5:pcie01: service driver pcie_pme loaded
[    0.478288] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.478312] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.478366] intel_idle: MWAIT substates: 0x20
[    0.478368] intel_idle: does not run on family 6 model 15
[    0.478454] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    0.478459] ACPI: Power Button [PWRB]
[    0.478504] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.478507] ACPI: Power Button [PWRF]
[    0.479901] ERST: Table is not found!
[    0.479903] GHES: HEST is not enabled!
[    0.479980] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.500351] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.610244] Freeing initrd memory: 14060k freed
[    0.792448] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.792671] Linux agpgart interface v0.103
[    0.794302] brd: module loaded
[    0.795091] loop: module loaded
[    0.795246] ata_piix 0000:00:1f.2: version 2.13
[    0.795258] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.795263] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    0.795301] ata_piix 0000:00:1f.2: setting latency timer to 64
[    0.795623] scsi0 : ata_piix
[    0.795712] scsi1 : ata_piix
[    0.796600] ata1: SATA max UDMA/133 cmd 0x9c00 ctl 0x9880 bmdma 0x9400 irq 19
[    0.796605] ata2: SATA max UDMA/133 cmd 0x9800 ctl 0x9480 bmdma 0x9408 irq 19
[    0.796626] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.796631] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    0.796677] ata_piix 0000:00:1f.5: setting latency timer to 64
[    0.796896] scsi2 : ata_piix
[    0.796977] scsi3 : ata_piix
[    0.797736] ata3: SATA max UDMA/133 cmd 0xac00 ctl 0xa880 bmdma 0xa400 irq 19
[    0.797739] ata4: SATA max UDMA/133 cmd 0xa800 ctl 0xa480 bmdma 0xa408 irq 19
[    0.797789] pata_acpi 0000:03:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    0.797826] pata_acpi 0000:03:00.0: setting latency timer to 64
[    0.797844] pata_acpi 0000:03:00.0: PCI INT A disabled
[    0.798149] Fixed MDIO Bus: probed
[    0.798167] tun: Universal TUN/TAP device driver, 1.6
[    0.798169] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.798223] PPP generic driver version 2.4.2
[    0.798322] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.798338] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.798358] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[    0.798361] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[    0.798415] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    0.798440] ehci_hcd 0000:00:1a.7: debug port 1
[    0.802308] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[    0.802321] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf7fff400
[    0.816018] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.816145] hub 1-0:1.0: USB hub found
[    0.816150] hub 1-0:1.0: 6 ports detected
[    0.816221] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    0.816232] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    0.816235] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    0.816280] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.816302] ehci_hcd 0000:00:1d.7: debug port 1
[    0.820195] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[    0.820209] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf7fff800
[    0.836019] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.836134] hub 2-0:1.0: USB hub found
[    0.836138] hub 2-0:1.0: 6 ports detected
[    0.836208] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.836220] uhci_hcd: USB Universal Host Controller Interface driver
[    0.836234] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.836240] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[    0.836243] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.836293] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    0.836322] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00008400
[    0.836450] hub 3-0:1.0: USB hub found
[    0.836458] hub 3-0:1.0: 2 ports detected
[    0.836518] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[    0.836524] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[    0.836527] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.836573] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    0.836602] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00008480
[    0.836724] hub 4-0:1.0: USB hub found
[    0.836728] hub 4-0:1.0: 2 ports detected
[    0.836787] uhci_hcd 0000:00:1a.2: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[    0.836793] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[    0.836796] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.836841] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    0.836864] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00008800
[    0.836985] hub 5-0:1.0: USB hub found
[    0.836988] hub 5-0:1.0: 2 ports detected
[    0.837048] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    0.837054] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    0.837057] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.837103] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    0.837124] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00008880
[    0.837244] hub 6-0:1.0: USB hub found
[    0.837248] hub 6-0:1.0: 2 ports detected
[    0.837306] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.837312] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    0.837315] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.837359] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    0.837380] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00008c00
[    0.837503] hub 7-0:1.0: USB hub found
[    0.837507] hub 7-0:1.0: 2 ports detected
[    0.837567] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.837573] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    0.837576] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.837621] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    0.837643] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00009000
[    0.837761] hub 8-0:1.0: USB hub found
[    0.837765] hub 8-0:1.0: 2 ports detected
[    0.837874] usbcore: registered new interface driver libusual
[    0.837910] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.840593] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.840600] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.840694] mousedev: PS/2 mouse device common for all mice
[    0.840846] rtc_cmos 00:03: RTC can wake from S4
[    0.840942] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    0.840962] rtc0: alarms up to one month, y3k, 114 bytes nvram
[    0.841038] device-mapper: uevent: version 1.0.3
[    0.841103] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    0.841110] cpuidle: using governor ladder
[    0.841111] cpuidle: using governor menu
[    0.841113] EFI Variables Facility v0.08 2004-May-17
[    0.841330] TCP cubic registered
[    0.841431] NET: Registered protocol family 10
[    0.841872] NET: Registered protocol family 17
[    0.841876] Registering the dns_resolver key type
[    0.842001] PM: Hibernation image not present or could not be loaded.
[    0.842014] registered taskstats version 1
[    0.848684]   Magic number: 13:897:849
[    0.848717] graphics fbcon: hash matches
[    0.848792] rtc_cmos 00:03: setting system clock to 2013-01-15 19:49:49 UTC (1358279389)
[    0.849494] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.849496] EDD information not available.
[    1.126703] ata4: SATA link down (SStatus 0 SControl 300)
[    1.204020] usb 2-4: new high-speed USB device number 3 using ehci_hcd
[    1.272051] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.280244] ata3.00: ATA-7: SAMSUNG HD154UI, 1AG01118, max UDMA7
[    1.280247] ata3.00: 2930277168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.288254] ata3.00: configured for UDMA/133
[    1.341648] Initializing USB Mass Storage driver...
[    1.341780] scsi4 : usb-storage 2-4:1.0
[    1.341843] usbcore: registered new interface driver usb-storage
[    1.341845] USB Mass Storage support registered.
[    1.446642] ata2.00: SATA link down (SStatus 0 SControl 300)
[    1.446655] ata2.01: SATA link down (SStatus 0 SControl 300)
[    1.448022] Refined TSC clocksource calibration: 2351.760 MHz.
[    1.448027] Switching to clocksource tsc
[    1.600057] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.600069] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.636009] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[    1.642150] ata1.00: ATA-8: ST3500418AS, CC34, max UDMA/133
[    1.642153] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.668198] ata1.01: ATA-8: ST3500410AS, CC33, max UDMA/133
[    1.668201] ata1.01: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.726144] ata1.00: configured for UDMA/133
[    1.782142] ata1.01: configured for UDMA/133
[    1.782254] scsi 0:0:0:0: Direct-Access     ATA      ST3500418AS      CC34 PQ: 0 ANSI: 5
[    1.782362] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[    1.782405] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.782420] sd 0:0:0:0: [sda] Write Protect is off
[    1.782424] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.782451] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.782516] scsi 0:0:1:0: Direct-Access     ATA      ST3500410AS      CC33 PQ: 0 ANSI: 5
[    1.782706] sd 0:0:1:0: Attached scsi generic sg1 type 0
[    1.782829] scsi 2:0:0:0: Direct-Access     ATA      SAMSUNG HD154UI  1AG0 PQ: 0 ANSI: 5
[    1.782941] sd 2:0:0:0: [sdc] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
[    1.782959] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    1.782988] sd 2:0:0:0: [sdc] Write Protect is off
[    1.782991] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    1.783014] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.785060]  sdc: sdc1
[    1.785263] sd 2:0:0:0: [sdc] Attached SCSI disk
[    1.803807] sd 0:0:1:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[    1.831875] sd 0:0:1:0: [sdb] Write Protect is off
[    1.831878] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[    1.848108] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.860797]  sda: sda1 sda2 < sda5 sda6 sda7 sda8 >
[    1.865267]  sdb: sdb1
[    1.865325] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.865462] sd 0:0:1:0: [sdb] Attached SCSI disk
[    1.867018] Freeing unused kernel memory: 924k freed
[    1.867229] Write protecting the kernel read-only data: 12288k
[    1.872493] Freeing unused kernel memory: 1604k freed
[    1.876729] Freeing unused kernel memory: 1196k freed
[    1.892216] udevd[109]: starting version 175
[    1.909303] xor: automatically using best checksumming function: generic_sse
[    1.928012]    generic_sse:  8728.000 MB/sec
[    1.928016] xor: using function: generic_sse (8728.000 MB/sec)
[    1.928672] device-mapper: dm-raid45: initialized v0.2594b
[    1.947633] pata_jmicron 0000:03:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    1.947667] pata_jmicron 0000:03:00.0: setting latency timer to 64
[    1.948114] scsi5 : pata_jmicron
[    1.948225] scsi6 : pata_jmicron
[    1.948391] ata5: PATA max UDMA/100 cmd 0xcc00 ctl 0xc880 bmdma 0xc400 irq 19
[    1.948394] ata6: PATA max UDMA/100 cmd 0xc800 ctl 0xc480 bmdma 0xc408 irq 19
[    1.948657] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.948674] r8169 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    1.948702] r8169 0000:02:00.0: setting latency timer to 64
[    1.948760] r8169 0000:02:00.0: irq 46 for MSI/MSI-X
[    1.949193] r8169 0000:02:00.0: eth0: RTL8168c/8111c at 0xffffc90000c66000, 00:19:66:ba:96:38, XID 1c4000c0 IRQ 46
[    1.949196] r8169 0000:02:00.0: eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[    2.044021] usb 8-1: new low-speed USB device number 2 using uhci_hcd
[    2.252819] usbcore: registered new interface driver usbhid
[    2.252822] usbhid: USB HID core driver
[    2.268950] input: MLK RA-ME wireless Laser combo set as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input2
[    2.269050] sunplus 0003:04FC:05D8.0002: input,hidraw0: USB HID v1.00 Keyboard [MLK RA-ME wireless Laser combo set] on usb-0000:00:1d.2-1/input0
[    2.296678] sunplus 0003:04FC:05D8.0003: fixing up Sunplus Wireless Desktop report descriptor
[    2.297399] input: MLK RA-ME wireless Laser combo set as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.1/input/input3
[    2.297991] sunplus 0003:04FC:05D8.0003: input,hiddev0,hidraw1: USB HID v1.00 Mouse [MLK RA-ME wireless Laser combo set] on usb-0000:00:1d.2-1/input1
[    2.303217] input: Twin USB Gamepad  as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input4
[    2.303301] input: Twin USB Gamepad  as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input5
[    2.303403] input: Twin USB Gamepad  as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input6
[    2.303487] input: Twin USB Gamepad  as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input7
[    2.303999] pantherlord 0003:0810:0002.0001: input,hidraw2: USB HID v1.10 Joystick [Twin USB Gamepad ] on usb-0000:00:1d.0-1/input0
[    2.304022] pantherlord 0003:0810:0002.0001: required output report is missing
[    2.340651] scsi 4:0:0:0: Direct-Access     ADATA    USB Flash Drive  0.00 PQ: 0 ANSI: 2
[    2.341104] sd 4:0:0:0: Attached scsi generic sg3 type 0
[    2.342275] sd 4:0:0:0: [sdd] 15378432 512-byte logical blocks: (7.87 GB/7.33 GiB)
[    2.342768] sd 4:0:0:0: [sdd] Write Protect is off
[    2.342770] sd 4:0:0:0: [sdd] Mode Sense: 00 00 00 00
[    2.343268] sd 4:0:0:0: [sdd] Asking for cache data failed
[    2.343270] sd 4:0:0:0: [sdd] Assuming drive cache: write through
[    2.347142] sd 4:0:0:0: [sdd] Asking for cache data failed
[    2.347145] sd 4:0:0:0: [sdd] Assuming drive cache: write through
[    2.348400]  sdd: sdd1
[    2.361766] sd 4:0:0:0: [sdd] Asking for cache data failed
[    2.361768] sd 4:0:0:0: [sdd] Assuming drive cache: write through
[    2.361771] sd 4:0:0:0: [sdd] Attached SCSI removable disk
[    7.762971] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[   24.180284] init: procps (virtual-filesystems) main process (402) terminated with status 127
[   24.197367] udevd[434]: starting version 175
[   24.374119] type=1400 audit(1358266813.019:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=554 comm="apparmor_parser"
[   24.374517] type=1400 audit(1358266813.019:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=554 comm="apparmor_parser"
[   24.374748] type=1400 audit(1358266813.019:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=554 comm="apparmor_parser"
[   24.602696] init: procps (static-network-up) main process (754) terminated with status 127
[   24.650574] device-mapper: multipath: version 1.3.0 loaded
[   24.827716] lp: driver loaded but no devices found
[   25.667287] nvidia: module license 'NVIDIA' taints kernel.
[   25.667290] Disabling lock debugging due to kernel taint
[   25.685429] Linux video capture interface: v2.00
[   25.788188] cx88/0: cx2388x v4l2 driver version 0.0.9 loaded
[   25.788227] cx8800 0000:01:00.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[   25.791718] cx88[0]: Your board has no valid PCI Subsystem ID and thus can't
[   25.791719] cx88[0]: be autodetected.  Please pass card=<n> insmod option to
[   25.791720] cx88[0]: workaround that.  Redirect complaints to the vendor of
[   25.791721] cx88[0]: the TV card.  Best regards,
[   25.791722] cx88[0]:         -- tux
[   25.791724] cx88[0]: Here is a list of valid choices for the card=<n> insmod option:
[   25.791726] cx88[0]:    card=0 -> UNKNOWN/GENERIC
[   25.791728] cx88[0]:    card=1 -> Hauppauge WinTV 34xxx models
[   25.791730] cx88[0]:    card=2 -> GDI Black Gold
[   25.791732] cx88[0]:    card=3 -> PixelView
[   25.791733] cx88[0]:    card=4 -> ATI TV Wonder Pro
[   25.791735] cx88[0]:    card=5 -> Leadtek Winfast 2000XP Expert
[   25.791737] cx88[0]:    card=6 -> AverTV Studio 303 (M126)
[   25.791739] cx88[0]:    card=7 -> MSI TV-@nywhere Master
[   25.791741] cx88[0]:    card=8 -> Leadtek Winfast DV2000
[   25.791742] cx88[0]:    card=9 -> Leadtek PVR 2000
[   25.791744] cx88[0]:    card=10 -> IODATA GV-VCP3/PCI
[   25.791746] cx88[0]:    card=11 -> Prolink PlayTV PVR
[   25.791748] cx88[0]:    card=12 -> ASUS PVR-416
[   25.791749] cx88[0]:    card=13 -> MSI TV-@nywhere
[   25.791751] cx88[0]:    card=14 -> KWorld/VStream XPert DVB-T
[   25.791753] cx88[0]:    card=15 -> DViCO FusionHDTV DVB-T1
[   25.791755] cx88[0]:    card=16 -> KWorld LTV883RF
[   25.791756] cx88[0]:    card=17 -> DViCO FusionHDTV 3 Gold-Q
[   25.791758] cx88[0]:    card=18 -> Hauppauge Nova-T DVB-T
[   25.791760] cx88[0]:    card=19 -> Conexant DVB-T reference design
[   25.791762] cx88[0]:    card=20 -> Provideo PV259
[   25.791764] cx88[0]:    card=21 -> DViCO FusionHDTV DVB-T Plus
[   25.791765] cx88[0]:    card=22 -> pcHDTV HD3000 HDTV
[   25.791767] cx88[0]:    card=23 -> digitalnow DNTV Live! DVB-T
[   25.791769] cx88[0]:    card=24 -> Hauppauge WinTV 28xxx (Roslyn) models
[   25.791771] cx88[0]:    card=25 -> Digital-Logic MICROSPACE Entertainment Center (MEC)
[   25.791773] cx88[0]:    card=26 -> IODATA GV/BCTV7E
[   25.791775] cx88[0]:    card=27 -> PixelView PlayTV Ultra Pro (Stereo)
[   25.791777] cx88[0]:    card=28 -> DViCO FusionHDTV 3 Gold-T
[   25.791779] cx88[0]:    card=29 -> ADS Tech Instant TV DVB-T PCI
[   25.791780] cx88[0]:    card=30 -> TerraTec Cinergy 1400 DVB-T
[   25.791782] cx88[0]:    card=31 -> DViCO FusionHDTV 5 Gold
[   25.791784] cx88[0]:    card=32 -> AverMedia UltraTV Media Center PCI 550
[   25.791786] cx88[0]:    card=33 -> Kworld V-Stream Xpert DVD
[   25.791788] cx88[0]:    card=34 -> ATI HDTV Wonder
[   25.791789] cx88[0]:    card=35 -> WinFast DTV1000-T
[   25.791791] cx88[0]:    card=36 -> AVerTV 303 (M126)
[   25.791793] cx88[0]:    card=37 -> Hauppauge Nova-S-Plus DVB-S
[   25.791794] cx88[0]:    card=38 -> Hauppauge Nova-SE2 DVB-S
[   25.791796] cx88[0]:    card=39 -> KWorld DVB-S 100
[   25.791798] cx88[0]:    card=40 -> Hauppauge WinTV-HVR1100 DVB-T/Hybrid
[   25.791800] cx88[0]:    card=41 -> Hauppauge WinTV-HVR1100 DVB-T/Hybrid (Low Profile)
[   25.791802] cx88[0]:    card=42 -> digitalnow DNTV Live! DVB-T Pro
[   25.791804] cx88[0]:    card=43 -> KWorld/VStream XPert DVB-T with cx22702
[   25.791806] cx88[0]:    card=44 -> DViCO FusionHDTV DVB-T Dual Digital
[   25.791807] cx88[0]:    card=45 -> KWorld HardwareMpegTV XPert
[   25.791809] cx88[0]:    card=46 -> DViCO FusionHDTV DVB-T Hybrid
[   25.791811] cx88[0]:    card=47 -> pcHDTV HD5500 HDTV
[   25.791813] cx88[0]:    card=48 -> Kworld MCE 200 Deluxe
[   25.791814] cx88[0]:    card=49 -> PixelView PlayTV P7000
[   25.791816] cx88[0]:    card=50 -> NPG Tech Real TV FM Top 10
[   25.791818] cx88[0]:    card=51 -> WinFast DTV2000 H
[   25.791820] cx88[0]:    card=52 -> Geniatech DVB-S
[   25.791821] cx88[0]:    card=53 -> Hauppauge WinTV-HVR3000 TriMode Analog/DVB-S/DVB-T
[   25.791823] cx88[0]:    card=54 -> Norwood Micro TV Tuner
[   25.791825] cx88[0]:    card=55 -> Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM
[   25.791827] cx88[0]:    card=56 -> Hauppauge WinTV-HVR1300 DVB-T/Hybrid MPEG Encoder
[   25.791829] cx88[0]:    card=57 -> ADS Tech Instant Video PCI
[   25.791831] cx88[0]:    card=58 -> Pinnacle PCTV HD 800i
[   25.791833] cx88[0]:    card=59 -> DViCO FusionHDTV 5 PCI nano
[   25.791834] cx88[0]:    card=60 -> Pinnacle Hybrid PCTV
[   25.791836] cx88[0]:    card=61 -> Leadtek TV2000 XP Global
[   25.791838] cx88[0]:    card=62 -> PowerColor RA330
[   25.791840] cx88[0]:    card=63 -> Geniatech X8000-MT DVBT
[   25.791841] cx88[0]:    card=64 -> DViCO FusionHDTV DVB-T PRO
[   25.791843] cx88[0]:    card=65 -> DViCO FusionHDTV 7 Gold
[   25.791845] cx88[0]:    card=66 -> Prolink Pixelview MPEG 8000GT
[   25.791847] cx88[0]:    card=67 -> Kworld PlusTV HD PCI 120 (ATSC 120)
[   25.791849] cx88[0]:    card=68 -> Hauppauge WinTV-HVR4000 DVB-S/S2/T/Hybrid
[   25.791851] cx88[0]:    card=69 -> Hauppauge WinTV-HVR4000(Lite) DVB-S/S2
[   25.791852] cx88[0]:    card=70 -> TeVii S460 DVB-S/S2
[   25.791854] cx88[0]:    card=71 -> Omicom SS4 DVB-S/S2 PCI
[   25.791856] cx88[0]:    card=72 -> TBS 8920 DVB-S/S2
[   25.791858] cx88[0]:    card=73 -> TeVii S420 DVB-S
[   25.791859] cx88[0]:    card=74 -> Prolink Pixelview Global Extreme
[   25.791861] cx88[0]:    card=75 -> PROF 7300 DVB-S/S2
[   25.791863] cx88[0]:    card=76 -> SATTRADE ST4200 DVB-S/S2
[   25.791865] cx88[0]:    card=77 -> TBS 8910 DVB-S
[   25.791866] cx88[0]:    card=78 -> Prof 6200 DVB-S
[   25.791868] cx88[0]:    card=79 -> Terratec Cinergy HT PCI MKII
[   25.791870] cx88[0]:    card=80 -> Hauppauge WinTV-IR Only
[   25.791872] cx88[0]:    card=81 -> Leadtek WinFast DTV1800 Hybrid
[   25.791874] cx88[0]:    card=82 -> WinFast DTV2000 H rev. J
[   25.791875] cx88[0]:    card=83 -> Prof 7301 DVB-S/S2
[   25.791877] cx88[0]:    card=84 -> Samsung SMT 7020 DVB-S
[   25.791879] cx88[0]:    card=85 -> Twinhan VP-1027 DVB-S
[   25.791880] cx88[0]:    card=86 -> TeVii S464 DVB-S/S2
[   25.791882] cx88[0]:    card=87 -> Leadtek WinFast DTV2000 H PLUS
[   25.791884] cx88[0]:    card=88 -> Leadtek WinFast DTV1800 H (XC4000)
[   25.791887] cx88[0]: subsystem: 0000:0000, board: UNKNOWN/GENERIC [card=0,autodetected], frontend(s): 0
[   25.791889] cx88[0]: TV tuner type -1, Radio tuner type -1
[   25.879894] nvidia 0000:08:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   25.879905] nvidia 0000:08:00.0: setting latency timer to 64
[   25.879910] vgaarb: device changed decodes: PCI:0000:08:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   25.880040] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  295.40  Thu Apr  5 21:37:00 PDT 2012
[   26.043423] i2c-core: driver [tuner] using legacy suspend method
[   26.043425] i2c-core: driver [tuner] using legacy resume method
[   26.047971] IR NEC protocol handler initialized
[   26.056984] tuner 0-006a: Tuner -1 found with type(s) Radio TV.
[   26.068070] IR RC5(x) protocol handler initialized
[   26.097923] cx88[0]/0: found at 0000:01:00.0, rev: 5, irq: 21, latency: 32, mmio: 0xf8000000
[   26.097960] tuner 0-006a: tuner type not set
[   26.098049] cx88[0]/0: registered device video0 [v4l2]
[   26.098136] cx88[0]/0: registered device vbi0
[   26.122987] IR RC6 protocol handler initialized
[   26.136508] IR JVC protocol handler initialized
[   26.190362] IR Sony protocol handler initialized
[   26.224964] IR MCE Keyboard/mouse protocol handler initialized
[   26.264001] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[   26.264014] hda_intel: msi for device 1849:0888 set to 0
[   26.264016] hda_intel: position_fix set to 1 for device 1849:0888
[   26.264070] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[   26.332641] lirc_dev: IR Remote Control driver registered, major 250
[   26.333078] IR LIRC bridge handler initialized
[   26.364352] hda_codec: ALC888: BIOS auto-probing.
[   26.372832] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   26.372947] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   26.373026] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   26.373103] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   26.373177] input: HDA Intel Line-Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[   26.373249] input: HDA Intel Line-Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[   26.373322] input: HDA Intel Line-Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[   26.373396] input: HDA Intel Line-Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[   26.576952] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[   26.576955] vesafb: scrolling: redraw
[   26.576957] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[   26.581072] vesafb: framebuffer at 0xfb000000, mapped to 0xffffc90011900000, using 5120k, total 5120k
[   26.581271] Console: switching to colour frame buffer device 160x64
[   26.581297] fb0: VESA VGA frame buffer device
[   26.789611] EXT4-fs (sda7): re-mounted. Opts: errors=remount-ro
[   34.091108] init: failsafe main process (972) killed by TERM signal
[   34.209894] type=1400 audit(1358266822.855:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=1065 comm="apparmor_parser"
[   34.212596] type=1400 audit(1358266822.859:6): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=1066 comm="apparmor_parser"
[   34.212995] type=1400 audit(1358266822.859:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1066 comm="apparmor_parser"
[   34.213223] type=1400 audit(1358266822.859:8): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=1066 comm="apparmor_parser"
[   34.214243] type=1400 audit(1358266822.859:9): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=1071 comm="apparmor_parser"
[   34.214753] type=1400 audit(1358266822.859:10): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=1071 comm="apparmor_parser"
[   34.216812] type=1400 audit(1358266822.863:11): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=1073 comm="apparmor_parser"
[   34.217179] type=1400 audit(1358266822.863:12): apparmor="STATUS" operation="profile_load" name="/usr/lib/telepathy/mission-control-5" pid=1069 comm="apparmor_parser"
[   34.218589] type=1400 audit(1358266822.863:13): apparmor="STATUS" operation="profile_load" name="/usr/lib/telepathy/telepathy-*" pid=1069 comm="apparmor_parser"
[   34.221013] type=1400 audit(1358266822.867:14): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince" pid=1067 comm="apparmor_parser"
[   34.255311] ppdev: user-space parallel port driver
[   34.274463] Bluetooth: Core ver 2.16
[   34.274482] NET: Registered protocol family 31
[   34.274484] Bluetooth: HCI device and connection manager initialized
[   34.274487] Bluetooth: HCI socket layer initialized
[   34.274488] Bluetooth: L2CAP socket layer initialized
[   34.274494] Bluetooth: SCO socket layer initialized
[   34.313338] r8169 0000:02:00.0: eth0: link down
[   34.313346] r8169 0000:02:00.0: eth0: link down
[   34.314201] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   34.390740] Bluetooth: RFCOMM TTY layer initialized
[   34.390747] Bluetooth: RFCOMM socket layer initialized
[   34.390749] Bluetooth: RFCOMM ver 1.11
[   34.403983] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   34.403986] Bluetooth: BNEP filters: protocol multicast
[   34.484780] NET: Registered protocol family 15
[   35.577681] Initializing XFRM netlink socket
[   35.634242] padlock_sha: VIA PadLock Hash Engine not detected.
[   35.696066] Intel AES-NI instructions are not detected.
[   35.740898] Intel AES-NI instructions are not detected.
[   35.979675] r8169 0000:02:00.0: eth0: link up
[   35.980543] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   46.176027] eth0: no IPv6 routers present
[ 1261.535108] r8169 0000:02:00.0: eth0: link down
[ 1266.230372] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1278.707618] r8169 0000:02:00.0: eth0: link up
[ 1278.708902] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1289.632012] eth0: no IPv6 routers present
and when i want to compile your driver give me this error:
Code:
  LD [M]  /home/nemanaldin/s2-liplianin-v37-udl/v4l/xc5000.ko
make[2]: Leaving directory `/usr/src/linux-headers-3.2.0-35-generic'
./scripts/rmmod.pl check
Can't locate Proc/ProcessTable.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at ./scripts/rmmod.pl line 4.
BEGIN failed--compilation aborted at ./scripts/rmmod.pl line 4.
make[1]: *** [default] Error 2
make[1]: Leaving directory `/home/nemanaldin/s2-liplianin-v37-udl/v4l'
make: *** [all] Error 2
i installed this package (libproc-process-perl) and compiled but i dont know its colmpiled completly or not
i rebooted system but i still have same error on dmesg
the solution I beleive is in the error log
it sais it cant determine what card you have and to manually tell it the card.
Can you do a
lspci -v -s 01:00.0
and paste the output, I'll check the drivers to see if the subsystem ID's etc are in there.
UDL
Set up question might be wrong forum but not sure.
Using RG-6 is so 80's. (IP-LNB)
