My Dad's having problems setting up his system to receive signals from 110/119 and 61.5 at the same time and neither of us can figure out why. We're both a couple of noobs so there's probably something basic that we're overlooking.
He has a dish500 (dual LNB w/ integrated switch) which works fine in picking up 110 & 119. He's using an 18" DirecTV dish to pickup 61.5 and is getting nearly perfect signal strength. Both dishes feed into an SW21 switch and out to the receiver, but when we run a check-switch only 110 and 119 are recognized. We can watch the regular channels but none of the international channels from 61.5. If we disconnect 110/119 from the SW21 switch and run a check-switch, 61.5 is recognized and we get the international channels but none of our regular channels. We first thought it was a bad switch so we got another one but still have the same problem. Is there a trick to hooking this up? From what I've been told, it's supposed to be an easy setup. Could someone point me in the direction of a setup guide if one exists. Should I be using a different switch or should I get another SW21?
Please help, we've already wasted a day on this.
