I thank you for your responses....
This is exactly what I have tried to do...eliminate the problem.
This is what I have done:
So as I understand it.... as long as the LNB and receiver are connected, and each is working, there should be a decent 'Q' reading?
Without knowing if your dish is pointed accurately, you should first be concerned with what you see on the SIGNAL LEVEL bar. The QUALITY LEVEL bar will come up when you are aimed properly at a good TP. If nothing shows in either, and especially in the signal level bar, you have a problem because the STB isn't even detecting anything from your LNBF and it should at least detect some amplifier noise. Your STB may be a little different, so someone else with personal experience should also chime in and offer some more specific information here.
Now that I have set the motor to the proper elevation and the dish to the proper elevation, if I stand back and take a look at the actual dish itself, it seems to me to be almost perpindicular to the ground. Not much of a tilt. But if I look at other dishes in the area, they seem to be on more of a tilt.
Don't judge the plumbness of the mast by the naked eye. Put a level on your mast and actually measure it. Measure the plumb in several positions around the mast. You do not want to be off east to west nor off north to south. Make sure it is perfectly level (vertically plumb). I mention this often to my friends here in my area and those on the websites, and I cannot stress it enough. You may be able to fudge on this or cut a corner if you are using a single, fixed point dish, but with a motorized dish, it is very critical.
I would also like to recommend the on-line angle calculator called FreeHostia. You can find this easily by Googling it. This is a very accurate calculator if your motor is included in the selection list (and most are). If you feed this calculator accurate information - and I prefer to use either the decimal degrees or degrees/minutes/seconds site coordinates - it will calculate your dish and motor angles very accurately. You will also not have to fret about the declination angle as that is figured into the calculation for you. The angles which are calculated will be within tenths of a degree or better in accuracy. You cannot even read the scales on your motor or dish that refined.
I have set up many motorized dishes using the information from this calculator for several different motor and dish models and makes and they have always proven to be spot on and follow the entire arc with USALS perfectly! There are some TPs or satellites that may be a little offset, but the majority will be right on the mark for you.
I am in the Hamilton Ontario area. If someone can chime in and help me out, that would be great!
Be certain that you check out SatBeams.com to determine of the sat and TP is going to be a strong and valid signal for your location and that your dish size is sufficient for the EIRP value. This is another excellent site to use for information.
One other site to mention for your assistance is the solar transit calculator (which tells you when the sun is perfectly aligned with a particular satellite during the spring or fall. You can find this calculator here:
Sun Outage Calculator
