larsh74 said:I have also had trouble with my meter using DPP LNBs. I like the idea of using a DP LNB to aim the dish. Could this also be done using a DP single on the 119 side? I have looked at that meter you are using several times and been tempted to buy it. Thnx for the advice and the link.
Yes you can use a DP single as well.
If you are looking for a signal meter/identifier that will work with DPP lnbfs, check the SatHawk 3000 (f.w V 5.1.6). It works well with DishPro Plus LNBFs and you will not need to waste time swpping LNBFs. The latest dataset for the meter version A4.2
