Well!!!
Where do I start. Hmmm!!
I will start in this thread because this is where the problem was identified and will do a full review in another thread when I am finished.
I got the GBox V3000 from Sadoun today as promised.
Did some preliminary work with the VBox III just so I would have data for comparisons sake, and so far I am impressed.
Hooked up the Gbox V3000 to my Unimesh dish in the same place that the VBox III was hooked at the center of my arc. Started moving the dish East and programmed in the positions one by one for each satellite and set the East limit just to the East side of 43W. Moved back to the center and started West ending just on the West side of 143W which is where 148W comes in for me with the DBS LNBF hanging off the east side of the feed-horn.
The following are some counts (pulses) as were counted by the VBox III and the GBox V3000.
This is from about 10 pulses East of 43W (IS3R) to about 10 pulses West of 143W (Echo 1,2) which is where the DBS LNBF (hanging off the side of the feed-horn) brings it in on this dish.
On the VBox III after adding the extra magnet to double the counts (pulses) the total pulses in the above arc is 597.
Switched out the VBox III and substituted the GBox V3000, and in the same arc as above, the total pulses is 1148.
Just for comparison, I have a VBox II on my Birdview dish and run it all the way from 30W - 142W with a 34:1 gear ratio motor (less pulses) and get 907 pulses with it.
The point is that the VBox III was not interpreting the pulse count correctly on a consistent basis.
Even if I hadn't doubled the counts by adding the extra magnet in the actuator, the new GBox V3000 would have given me 574 pulses which is almost as much as the VBox III is giving me with the added magnet and counts.
The accuracy of the landing points on each satellite has greatly improved, but still have a lot of testing to do before I do the final review.
But this is a good place to continue the discussion.
All current owners of the VBox III, take note of the above.
