Okay guys,
Getting ready to rock and roll with the Pansat 3500SD and Vbox II combined with the HT System VIII Plus analog unit. I hooked everything up last night as instructed on this site using the add a receiver link, but didn't turn anything on untill a short while ago. I wanted to see if the HTS unit would function with the Vbox II as a stand alone positioner. The Vbox II works and moves the 10" BUD okay. The problem I have, is getting the HTS to move to a different stored satellite. Because the motor is not hooked up, it gives a motor error.
So my question is the following in several parts:
Can I erase my stored satellites that I currently have programmed?
Proceed with the Pansat setup, write down the location of each satellite that shows on the Vbox screen position number?
Come back later to the HTS and re-program each satellite again using the Vbox II positions for movement, and have more than one satellite stored in what will be the same position as far as the HTS is concerned, so it doesn't think it has to move the dish when I change stellites?
I think this can be done, but wanted to be sure.
Just so I am clear on what I am trying to achieve. I have the HTS and Pansat both hooked together as shown above. I want the Pansat to control dish movement using DiSeqc and USALS. I have an A-B swith setup to alternate between allowing the Pansat to control polarity when using it, and allowing the HTS to control polarity when using it.
When using the HTS analog, I will first move the dish with the Vbox II, and then change satellites using the HTS after they are re-programmed and stored as above if that will work.
I am sure I will have a few questions as I proceed with the Pansat, but wanted more minds than mine on the HTS problem above.
