Being new to FTA I'm having trouble setting up my system.
I have a Geosatpro 36" dish mounted on a sg9120 motor hooked up to a coolsat 5000 platinum.
I'm a little confused with the angles on the dish and motor but have tried my best to set them according to the manuals.
I've set the Latitude on the motor and then adjusted the dish as the manual states.(dish angle=90deg. -your site latitude - declination angle) but another place in the manual it says the reading on the dish should be 40 deg - declination angle. I've tried both numbers and I can't seem to lock on to 97W. One thing I've noticed is that if I set the Latitude to 41 on the motor mount the elevation angle setting on the other side of the mount does not match what the chart in the manual says, which is 49. Which setting should I use the elevation or the latitude?
I've aimed the dish to true south and lined up the dish with the motor. The mounting pole is perfectly plumb.
I've also set the receivers settings for the lnb to single 10750 and the motor to USALS. The receiver moves the dish motor when I go to 97W
On the instructions for the dish it states to mount the lnb as far back in the mount as you can. I have the lnb skew set at 0 and have it pushed back to the edge of the white plastic front cover in the mount. (all that sticks out of the mount is the white plastic cover)
The receivers signal meter has almost no quality and 89 to high 90's for strength.
I'm not sure what else to check. All advice is welcome.
One other thing is the receiver is used. I downloaded the latest firmware from this forum and upload it without any problems. I don't think its the receiver because all the menus and editing of commands work just fine.
Thanks for all help and advice in advance.
