Ok guys, for those of you who have primestars on motors what did you use to fill in the gap between the neck of the motor and the neck of the primestar.
I drilled a hole in the side of the primestar neck on both sides to put a screw through the holes that are allready there in the neck of the motor. IT works great to keep it stable but he problem is is the dish moves up and down.
What did you use to stabelize it? Or what did you wrap around the neck of the motor to keep the dish from slipping off? Thx.
