Primestar Dish on SG2100 ?
primestar and new stab 120 hh motor
PSB said:
Was it a Moteck SG2100 or some other name?
Also did you remove as much metal from the dish as possible?
No I did not/just added some 2"pvc pipe for shim. But having problems.I just now see these post about the sg 2100 hh motor. And how to make it liter.I am tring to find my elevation/Sadoun site say 23.5,pansat book say 24.When I used satfinder it say 41.8. So I am very confuse. I got 3 hh motors,76cm on my sg 2100.My 75cm hot dish(which I could not get a picture on) is in the garrage.I also have a pansat pm 900 hh motor/I was told by pansat the my 3500 would not work with a sg2100.They was wrong.Thank guys I love this.
When you put a satellite dish on an SG2100 the dish elevation is always around 24-25º
This dish elevation can be changed slightly to catch and peak the signal.
Most web site will give you the elevation for a FIXED dish not a dish on a motor!
Needing a little help!
I am going to put up my Primestar dish for my motor this weekend and I have been reading the post and it has been very helpful. But I am having a hard time finding out what my true south sat is and My zip is 29316 in South Carolina. And I would like to know what my declination angle is as well and Thank you for the help in advance. GO STEELERS!!!!!
your true south is the closest to whatever your longitude is. In your case Nimiq at 82W. Here are all the angles you need. My list is kind of old so there are a few obsolete entries.
Spartanburg, SC 29302
Latitude 34° 57.378'N Longitude 81° 52.416'W
Sat Name Sat Lng Az(t) Az(m) El Skew
*** Of Particular Interest ***
EchoStar 3 61.5W 147.0 153.8 44.0 -26.5
EchoStar 6 110.0W 223.0 229.8 39.6 34.0
EchoStar 8 110.0W 223.0 229.8 39.6 34.0
EchoStar 7 119.0W 232.9 239.7 33.6 40.8
EchoStar 5 119.0W 232.9 239.7 33.6 40.8
EchoStar 9/Telstar 13 121.0W 234.8 241.6 32.1 42.1
EchoStar 1 148.0W 255.8 262.5 10.8 52.6
EchoStar 2 148.0W 255.8 262.5 10.8 52.6
EchoStar 4 157.0W 261.3 268.1 3.5 54.1
DirecTV 3 81.8W 179.9 186.6 49.4 -0.1
DirecTV 2 100.8W 210.9 217.7 44.7 24.9
DirecTV 1R 100.8W 210.9 217.7 44.7 24.9
DirecTV 1 101.0W 211.2 218.0 44.6 25.1
DirecTV 4S 101.2W 211.5 218.2 44.5 25.3
DirecTV 6 109.8W 222.8 229.5 39.7 33.8
DirecTV 5 119.0W 232.9 239.7 33.6 40.8
*** All Satellites 61W - 160W ***
Rainbow 1 61.5W 147.0 153.8 44.0 -26.5
Brasilsat A2 (incl. 5.8 deg) 63.0W 149.2 155.9 44.7 -24.8
Brasilsat B2 65.0W 152.1 158.9 45.6 -22.5
Brasilsat B1 70.0W 159.8 166.6 47.5 -16.4
Nahuel 1 71.8W 162.8 169.5 48.0 -14.0
AMC 6 72.0W 163.1 169.9 48.0 -13.8
Galaxy 12 74.0W 166.4 173.2 48.5 -11.1
SBS 6 74.0W 166.4 173.2 48.5 -11.1
GOES 12 75.0W 168.1 174.9 48.7 -9.7
AMC 5 79.0W 175.0 181.8 49.3 -4.1
Nimiq 2 82.0W 180.2 187.0 49.4 0.2
Brasilsat B3 84.0W 183.7 190.5 49.3 3.0
XM Roll 85.0W 185.4 192.2 49.3 4.5
AMC 9 85.0W 185.4 192.2 49.3 4.5
AMC 3 87.0W 188.9 195.7 49.0 7.3
Galaxy 9 91.0W 195.7 202.4 48.2 12.8
Galaxy 11 91.0W 195.7 202.4 48.2 12.8
Nimiq 1 91.0W 195.7 202.4 48.2 12.8
Brasilsat B4 92.0W 197.3 204.1 48.0 14.1
Telstar 6 93.0W 198.9 205.7 47.7 15.4
Galaxy 8I (incl. 1.0 deg) 95.0W 202.1 208.9 47.0 18.0
Galaxy 3C 95.0W 202.1 208.9 47.0 18.0
Telstar 5 97.0W 205.3 212.0 46.3 20.5
Inmarsat 2 f2 (incl. 1.7 deg) 98.0W 206.8 213.5 45.9 21.7
Galaxy 4R 99.0W 208.3 215.0 45.5 22.8
AMC 4 101.0W 211.2 218.0 44.6 25.1
AMSC 1 101.1W 211.3 218.1 44.5 25.2
AMC 1 103.0W 214.0 220.8 43.6 27.3
Solidaridad 1 (incl. 2.8 deg) 103.5W 214.7 221.5 43.3 27.8
AMC 2 105.0W 216.7 223.5 42.5 29.3
G-Star 3 (incl. 11.5 deg) 105.0W 216.7 223.5 42.5 29.3
G-Star 1 (incl. 6.0 deg) 105.0W 216.7 223.5 42.5 29.3
MSAT 1 106.5W 218.7 225.4 41.7 30.8
Anik F1 107.3W 219.7 226.5 41.2 31.6
Anik E1 109.2W 222.0 228.8 40.1 33.3
Anik E2R 111.1W 224.3 231.1 38.9 34.9
Solidaridad 2 113.0W 226.5 233.3 37.7 36.5
Morelos 2 (incl. 4.4 deg) 114.9W 228.6 235.4 36.4 37.9
XM Rock 115.0W 228.7 235.5 36.3 38.0
SatMex 5 116.8W 230.6 237.4 35.1 39.3
Anik E2 118.7W 232.6 239.4 33.8 40.6
Galaxy 10R 123.0W 236.7 243.5 30.6 43.3
Galaxy 5 125.0W 238.5 245.3 29.1 44.4
Galaxy 12 125.0W 238.5 245.3 29.1 44.4
Galaxy 13 127.0W 240.3 247.1 27.6 45.4
Telstar 7 129.0W 242.0 248.8 26.1 46.4
Satcom C3 131.0W 243.6 250.4 24.5 47.2
Galaxy 1R 133.0W 245.2 252.0 22.9 48.1
Satcom C4 135.0W 246.7 253.5 21.4 48.9
GOES 10 135.5W 247.1 253.9 21.0 49.0
AMC 7 137.0W 248.2 255.0 19.8 49.6
AMC 8 139.0W 249.7 256.5 18.2 50.2
Inmarsat 2 f3 (incl. 1.9 deg) 142.0W 251.8 258.6 15.7 51.1
TDRS 9 (incl. 7.4 deg) 151.0W 257.7 264.4 8.4 53.2
TDRS 10 (incl. 6.2 deg) 151.0W 257.7 264.4 8.4 53.2
Satellite Finder is (c) Copyright 2004, P. Lutus
Hello All-- I am trying to build my own light-weight mount for my dish to motor. I am using the messages and pictures above as a model. My problem is that I need a mechanism to change the dish elevation. Other members seems to have taken them from other dishes/mounts. I don't have any to pirate from. My dish is a CM 1.2 M and my motor has a 55mm thick shaft (hard to fit to)(points down). Any ideas where I can get the part I need? THANKS!!
Mercury II and duplicate channel numbers
Fortec Star Dishes
