jarrodk said:
I am in the process of building a new house, and am running all of my coax cables to one location in the basement. How do I determine the following:
1) Where will the DISH Network dish need to be located on my house;
2) if it's the opposite end of my central location of all coax cables, what cable type (and how many cables) do I need to run from the proposed dish location to the central location?
I'm assuming I'll need RG6 cable, but that it will need to run directly from the dish location to the location of each receiver.
Ideally, I'd like to have it prewired so I do not need to drill holes in the new walls and/or fish wiring through the siding.
Also, which dish should I be looking at installing for bext long-term flexibility? Is the SuperDish the way to go?
Thanks,
Jarrod
Welcome Jarrod!
Here is what I did and this may help guide you.
Home Distribution System
Well here is what I did 5 years ago and at present do I look smart. Is this future-proof, who knows?
I ran two RG-6 cables to two locations in most rooms. The thinking was one-in and one-out, or two-in. I had one location in the kitchen and sewing room, but all other rooms have two, just in case rooms are re-arranged. I also did the same with phone lines. Two lines everyplace I put phone lines (like any location I could place a TV in the future) and close to any TWO video cable install. I figured that could be on the wall like a Plasma flat screen, and maybe that TV signal would come by phone lines? Remember this was five years ago, and now that is about to happen.
I then had all cables (something like 24?) ran to the garage where I had installed a video distribution cabinet in the wall with a powered electric outlet. I also purchased a powered video 3X8 distribution panel to mount inside. These items were purchased from Smarthome.com, back then. I had numerous cables ran to the back of my big screen as outputs (could be inputs). I had five cables ran from the satellite dish to this location. I later added another four, but now the “single cable solution” is available from DISH and soon from DirecTV. With DVRs taking two input cables in the past, I ran out of cables, but now that may not be an issue.
I had Cable TV for locals back then and used it w/o power to feed them to one of five CRT TVs, and also DirecTV from one of two receivers to every other location. With the SD DirecTV Tivo (not the HD DVR) I could run the extra output to any room(s). Worked fantastic, with great PQ, just used the proper cable and proper splitter. I could run any source that used cable to and from any TV.
I added the original VOOM HD to my DirecTV complete with their free OTA outside antenna, then DISH to my DirecTV to keep VOOM programming. Their 942 and now their VIP 622 DVR have SD output so I use the TWO RG-6 as inputs to my new three LCD screens and even my Windows XP Media Edition computer! I am using the powered 3X8 now with great results.
I can view any SD DirecTV Tivo DVR live or recorded program on all five screens. I can view any DISH SD or HD recorded or live on all five screens plus OTA live or recorded since the OTA old VOOM antenna is utilized. I did use a low tech A/B chrome slide switch @ each screen (3 LCDs and computer) and made custom RG-6 cables. I programmed each set for only two stations and also the media player. The A/B switches are marked “DirecTV” and ”VOOM” (DISH) so all you need to do is place it in the proper input position and the hit the channel up or down once.
I bought a Tivo remote from Weakness that controls both of my Tivo DVRs (one SD & one HD) modified it to be a whole house remote. The DISH DVR comes with a second whole-house remote anyway. We can control input and DVRs from any location in the house. I can be watching something in the “Home Theater Room” or on the computer in my home office and she can be watching something else (and skipping commercials if she wants) in her sewing room. It is a really user friendly system that even my Wife can use! Yes there are only two of us with five screens. Stranger yet to most of our friends is that we usually never watch “Live TV”. It is common here but not main stream.
It was not expensive to install as we had the house built. I was really concerned since this is our last home being in a retirement community when you must be 55 and older (except for maybe a nursing or funeral home!) and is built on a slab with brick walls. I have never owed a home before that I couldn’t run cables in a craw or basement. Our previous home was also custom built and we realized how much pleasure and cost savings could be accomplished with just a little planning. Right now I couldn’t be happier with our video set-up, DISH and the LCDs PQ (yes computer screen is a LCD, too). Can’t say much good about DirecTV presently, but maybe that will change next year. GOOD LUCK and enjoy!
