He gave the exact model number of the lnb. It's a swm. He also said he has an H23. No b band converter needed. The information is all in the first post.
Oh really? Then why is he getting signal strength numbers? Don't say it's because he doesn't have a swm lnb, he does. He identified it by the model number.It won't work without a power inserter.
An HR54 and an H44 have built in power inserters. Do the other Genies put out any voltage? Maybe not since they require a power inserter.I think its working because its not a SWM ONLY recvr.
Its getting the 18v from the H23, just enough to power it.
If it was a Genie, it would not be working at all.
Correct ...An HR54 and an H44 have built in power inserters. Do the other Genies put out any voltage? Maybe not since they require a power inserter.
When the receiver is in SWM mode it does not send power to the lnb, unless it's an HR54, or Genie2
That's with the addition of the power inserter?Hey Guys,
I got great signals on 101*, like 95-98 and even a 100, my 99* and 103* are up in the 90's...at least a 20 point gain!
I'd say it was the alignment that upped your numbers and not the addition of the power inserter. I'd also say that adding the power inserter saved the power supply in the H23.I added the power inserter and still had to do an alignment on the dish, thank everyone for your responses.
Any receiver compatible with a DECA outputs power in SWM mode, otherwise the DECA would not work. Did you think they are powered by hopes and dreams?
And except for the H44 and except for the HS17.You need a power inserter when used in SWM mode, except for the HR54
