Please check my math...
Hey, thats what we are here for.. not too long ago I was in the same spot as you.. first dish, no clue where to point it, and lots of headaches.. then I found this place ;)
Dont worry, we will get you going in no time.
OK, Quick questions about LNB's
1. I got a Fortec Star FSKU-V lnb with my dish. What should my setting be in the Pansat 3500s? Choices Are:
a. Universal 1 (9750MHz & 10600MHz)
b. Universal 2 (9750MHz & 10750MHz)
c. Single-SL (5150MHz & 5750MHz)
d. Single-SH (5150MHz & 5750MHz)
e. Standard (10750 or 11250)
f. Single Stack (10750(v) / 10175(h))
2. I have an spare DirecTV LNB. Is this a circular LNB?
3. If I connect the DTV LNB to the Switch, What should the LNB setting be? (from the choices above)
4. For Questions 1 and 3, should I change the SKEW? The default is 45.
Thanks again to you all. This fourm is great.
Sincerely,
1. Universal 1
2. Yes.
3. 11250
4. No skew is needed with a circular LNB.
about #4.. are you refering to the Skew setting in the reciever? Leave those as is, I believe that is for a polarity servo for c-band lnbfs
