Got a quick reply, only an hour and 15 after they technically opened.
• ?Room is about 3300sqft, which falls under your "3" category, and that appears the VTF-2 is just right for me Can you send a detailed sketch of your room?
• ?My sub sits beside my ent. center, with a wall to its back. I would most likely use the sub with one port open for max extension (100% movies and I figure this is best), so how far does the port need to be from the wall? All you need is about 3" of space. Actually, I would go for two ports open for movies. Most movies do not go below 25 Hz, and the higher headroom in two ports open mode is helpful for the loud explosions. You can always set it to one port open for the movies that has extension below 25 Hz (easy enough to plug up one port), but for most movies, both ports open will yield lower distortion.
• ?Woofer is firing down into carpet/pad, over concrete foundation. Is this OK, or does it need MDF underneath (old cheaper sub did) No need for MDF.
• ?I have a Denon AVR, with Audyssey. I assume sub setup is normal as any other. Place it, set gain/volume to 50%, put sub in the mode I want to use (max ext), and then run Audyssey? I would set the volume on the sub to about 9 o'clock, one port open, EQ1, Q=0.7 for the Audyssey run, and then change it to EQ2, both ports open and fine tune by ear with the Q control.
Their answers in red, and I just sent them a drawing of my layout. I gotta admit, the Audyssey answer looks like chinese to me
