I am in North Dakota...
Then you should be getting better signal levels. I would call and tell them that you experience signal loss when it rains. They should be able to get better readings off 129.
I recently upgraded from a SuperDish 121 + DPP44 + 942/811 setup to a Dish 1000.2 + 622/211 configuration. I am getting a signal level of only high 40's / low 50's on many transponders on the 129 bird. Some transponders are in the 50's - 60's range and a few come in at high 70's (therefore I am getting a range like 48 - 78) The HD channels all seem to be coming in fine. Should I just leave it as is ("don't fix it if it ain't broke") or should I call Dish Tech support and have them come and re-point the dish? What, if anything is the disadvantage of having signal levels below 50? (since I seem to be getting the HD channels just fine). I must mention that the installer peaked for the 129 bird with just a single spare LNB, fixed the Dish in that position and then attached the Triple LNB of the Dish 1000.2...Was this correct? I recall reading somewhere that the dish 1000.2 needs to be peaked for the 119 bird and that the other two birds will then automatically come in at maximum levels. Any thoughts on this? Incidentally, I get good signal levels in the 80's and 90's on the 110 and 119 birds.
There is a recent thread saying that in the year 2009.
I've heard that the 129 signal is not all that great in the western part of the U.S (especially the west coast) so that may be the best you can get for the 129... not sure though. One option would be to add a wing dish pointed at 61.5 (the 1000.2 LNB has an input for a fourth orbital slot)I'm in a similar predicament, but I haven't yet checked the various transponders. I live in the Boise, ID area, and just upgraded to a 622 and the 1000.2 dish. Our local channels are breaking up. 110 and 119 show in the low 80s, while 129 hovers around 48-51. I called Dish tech support, and they're sending someone out to fix it early next week. Given my location, what could I reasonably expect for 129? I just want to make sure I'm getting the best signal possible, I'd rather not have to deal with another service call.
thanks!
Location, location, location. Lucky you Mike that you can get those readings off 129. Unfortunately, not everyone can get those readings unless they setup a second and bigger dish.
And you see....this is my biggest b*tch with Dish right now. They emphasize and impress upon the techs to use the 61.5 as a last resort. Yet, the 129 is the biggest POS this side of the 105. Worse...their premium/HD programming resides there. If anything, you would expect your HD bird to be the best and most powerful out of the fleet.
The reason I ask is that there's a big difference in TP strength with 129. TP 30 and 31 are pretty high around 90 but the rest of TPs are usually around 60s or 70s. So if you have 83 in a TP different than 30 and 31 then it's very good.
