Picture not centered, help
I'm sorry. I had it backwards. Channel Down and Vol down. The other way wouldn't have hurt your TV.
http://www.hometheaterspot.com/htst...er=387268&page=2&view=expanded&sb=3&o=&fpart=
Here is a thread talking about it.
All I changed was Horizontal to move the picture right. The overscan was too much to the left.
The settings for what you want to do should be in the service menu. Be sure to do an auto convergance when you are finished. :)
rkr0923 said:
munscher.....so what code did you use and where did you find the gemoetry settings?
I can't find that one :confused:
sorry, i used 062596 STATUS to get to the geometry settings
How I "fixed" it.
I just had Voom installed over the weekend and had the same problem with my 65" Apex widescreen. I can not change anything within my sets settings so I figured out how to get the menu back on the screen using the receivers setting. I can't really notice a difference in quality either. You can always change this back too. Here are the steps to follow.
1) Press the Voom button on remote
2) Press the Green button - Options & Settings
3) Select System Settings
4) Select Installer Menu
5) Select Installation Wizard
6) Select Set Output Resolution
7) Press Green button - 720p
8) Press OK button
9) Press Watch button below Voom button
:D Enjoy! - You can always go back to 1080 when you want to.
Tony
