H hanson Well-Known SatelliteGuys Member Original poster Apr 15, 2009 32 0 ky. May 3, 2009 #1 on the this network channel on amc 3,i have picture but no sound. i've entered the vid and aid numbers,but still no audio. any suggestions on what to do?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,703 11,808 Mankato, MN May 3, 2009 #2 ThisTV is AC-3 audio so you need a receiver that decodes dolby digital and an audio receiver that can do the same thing too Or a HD receiver will do the trick
H hanson Well-Known SatelliteGuys Member Original poster Apr 15, 2009 32 0 ky. May 3, 2009 #3 using a fortec ultra,but recently bought a coolsat 5000. will the coolsat decode the audio,i've not used it yet?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,703 11,808 Mankato, MN May 3, 2009 #4 both will decode the audio but you need a audio receiver that can decode it too
Corrado SatelliteGuys Pro Apr 2, 2007 2,428 303 Hudson Valley Region, NY May 4, 2009 #5 The affiliates for thisTV on G18 are not AC3 audio. The Fortec should be fine if you have ku band capability.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,703 11,808 Mankato, MN May 4, 2009 #6 correct Corrado. The C-Band feed is AC-3 but the KU ones arent
Corrado SatelliteGuys Pro Apr 2, 2007 2,428 303 Hudson Valley Region, NY May 5, 2009 #7 I forgot that WNGS on G3C-95°W C band, is a thisTV affiliate. Perhaps you could try that while it lasts. I don't know how long it will remain there.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,703 11,808 Mankato, MN May 5, 2009 #8 true....since Daystar bought that station, it could be any time
