I would suggest getting a jack tester at a home improvement store before tearing the jack about to check. Home Depot has one for about $10 that can tell you if the polarity is switched and if there is any AC on the line.
I've got an hr20 and hr21 both on my Vonage line and they work and use caller ID flawlessly! I bet you have the polarity swapped at the jacks and this is causing the problems.
Great thought!
Believe it or not, I have the EXACT same problem. Do you by any chance have AT&T?
No I have Vonage. You have a HR-22 receiver?
Any suggestions as to how I can handle this and get some results??
Ok - this has been bugging me all day. So, off to Lowes and I bought a phone line tester.
I just checked every lousy phone jack in the house. All come back "Line correct".
So now I am stuck with 2 - two day old HR-22's that kill my phones when plugged in.
I am assuming this is going to be an uphill battle. First, D* is going to tell me "You dont need that phone line plugged in considering you have the ethernet connection" then "we find it nearly impossible that you have two receivers with the same problem".
Or another possibility is that your overloading the number of lines you can put on your vonage device. I have four lines connected to my Motorola/Vonage router. Two are phone lines, one to my HR20 and one to my HR21. Mine work correctly and Caller ID works on the second ring with data.
Maybe you have another device other than the Motorola for Vonage??
