excellent suggestions there don.Yes, I used to use a small air compressor at low psi too until after a cleaning one of my DVD drives started causing bad disks. I replaced the drive as that was a fairly cheap and quick solution but decided to take it apart and have a look. The inside was pretty obvious around the back connections opening the dust had built up. Looked like I had blown the dust into the drive. Further inspection with magnifier head gear, I could see micro dust particles on the laser lens.
As for compressed air blowing a surface mounted part off- It seems that is impossible unless that part was not properly soldered and would soon fail anyway. And, while I'm no professional at this, just have a good education in electronics, I know that static electricity can happen so the best advice is to make sure your case and your tools are bonded and grounded and then the likelihood of a spark is quite remote.
found the link frank Be cool! Be Aerocool!Even though I clean mine, I would like to filter the air. Just seems like the right thing to do. I look forward to your link.
:Now that is a very interesting design. I would really like to put my hands on one and take a closer look. Cool! No pun intended. Thanks for the link.
My son has built 2 computers using this case because he liked it so well
Newegg.com - Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Gaming Case
SatelliteGAL said:My son has built 2 computers using this case because he liked it so well
For my business, I take all 3 PC's outside (nice day) once a year, open the cases and blow them out with an air compressor at a distance of about 2 feet. It gets all the dust out of every nook/cranny and they look brand new by the time I'm done. Then I let them sit for about 10 minutes before taking them back in and closing/hooking everything back up. Never had a problem with a PC doing this...
