I just did a scan of all the transponders on lyngsat's AMC3 list (plus a few extras). I'm trying to hunt down a workable PBS, but before I close this scan results window I noticed the following 'discrepencies' (extras included)...
11726 V - NMSU - New Mexico State University Instructional TV
Transponder locked in, but nothing on it. Not too worried about this one
11817 V - There is no audio track! (Unplayable)
11898 V - There is no audio track! (Unplayable)
11984 V - GPTV - Nothing found, No transponder... ?
12005 V - There is no audio track! (Unplayable)
12048 V - Florida Stuff - Transponder locked in, nothing found on it... ?
12096 V - PBS - Nothing found, No transponder... ?
12140 V - WYDN - Nothing found, No transponder... ?
12180 V - PBS - Nothing found, No transponder... ?
11719 H - The Patient Channel - Transponder locked in, nothing found on it... ? Again, not terribly worried about this one either.
11971 H - Channel 5 - Washington - Weak signal, maybe also encrypted.
12072 H - LPB / PBS - Nothing found, No transponder... ?
12110 H - PBS - 5 Channels at 31% Quality, VERY rarely gets a picture for a second.
12128 H - PBS HDTV - Nothing found, No transponder... ?
12151 H - CPB - Nothing found, No transponder... ?
12161 H - PBS Feed - Weak Signal, but enough to see it works.
12164 H - Montana PBS - Transponder locked in, nothing found on it... ?
I didn't include all the stuff I actually found that should be there. So I would assume I'm not finding everything due to 1) dish not being 'peaked' enough on this sat or 2) my Twinhan can't understand DC2. The problem with the latter is it found the PBS Feed on 12161 H, which is supposed to be DC2.
I'm hoping some kind person will let me know if these are just the weakest transponders I'm having trouble getting, or is it something else?
I'm going to try peaking the dish a bit, though the lnb is already slid all the way back (which improved things by several % in quality on most sats) and the left/right using the SG2100 is peaked too. Maybe a little height adjusting? From what I understand, skewing the lnb is pointless with a motor.
PS. Is that Rush on 11723 H, left side audio? :
