PBS ANNOUNCES HIGH DEFINITION FEED
FOR BACKYARD DISH USERS
Analog Service to End November 15, 2010
A High Definition (HD) digital “clear feed” of PBS programming is now available to serve households that use satellite receiving antennas (backyard dishes) to directly access video programming. Since May 2010, backyard dish users have had access to both an HD and an SD (Standard Definition) feed of the PBS National Program Service from the AMC-1 satellite at 103 degrees West Longitude.
Accordingly, PBS is announcing that the Analog C-Band transmissions of PBS programming, currently on Transponder 16 of the SES-1 satellite at 101 degrees W.L., will be discontinued as of November 15, 2010. Before November, in order to assure that all viewers in the backyard dish community are aware of the new enhanced service, PBS will also be vigorously promoting the new HD and SD services nationwide. To provide ample customer service to users, an 877 phone number (877.727.4144) and an email address (backyardfeeds@pbs.org) are available for anyone to obtain information from PBS about the new feeds. In addition, announcement of the digital service will also be made within the analog program service by a message superimposed on the video of the analog feed.
Benefits of the Change to Digital
Conversion of the PBS Clear Feed to digital transmission will:
• Preserve an open PBS satellite program service in the most widely used transmission format available;
• Allow PBS to offer both High Definition (HD) and Standard Definition (SD) services because of the higher efficiency of digital transmission;
• Allow PBS to provide 5.1 surround sound to the backyard dish community on High Definition programs; and
• Will be in line with the nationwide conversion to digital over-the-air television
A Fact Sheet with details about how to access the digital clear feed, or obtain additional information, is attached.
About PBS
PBS, with its nearly 360 member stations, offers all Americans — from every walk of life — the opportunity to explore new ideas and new worlds through television and online content. Each month, PBS reaches more than 118 million people through television and nearly 21 million people online, inviting them to experience the worlds of science, history, nature and public affairs; to hear diverse viewpoints; and to take front row seats to world-class drama and performances. PBS’ broad array of programs has been consistently honored by the industry’s most coveted award competitions. Teachers of children from pre-K through 12th grade turn to PBS for digital content and services that help bring classroom lessons to life. PBS’ premier children’s TV programming and its website, pbskids.org, are parents’ and teachers’ most trusted partners in inspiring and nurturing curiosity and love of learning in children. More information about PBS is available at PBS, one of the leading dot-org websites on the Internet.
CONTACT:
Jan McNamara, PBS, 703-739-5028; jmcnamara@pbs.org
TECHNICAL FACT SHEET ON PBS DIGITAL CLEAR FEED
August, 2010
The PBS digital clear feed can be received by readily-available digital consumer receivers. The feed is on Transponder 20 of the AMC-1 satellite located at 103 degrees West Longitude.
Technical parameters of the feed are:
AMC-1, 103 degrees West Longitude
C-Band Transponder 20 (Vertical polarization)
DVB-S QPSK modulation
Carrier Center Frequency: 4091 Mhz (1059 Mhz L-Band)
Symbol rate: 14.028731 Msps
The feed is MCPC with two services:
1. High Definition Service: MPEG Service # 3
Video PID: 49 (decimal) / 31 (hex) MPEG-2
Audio1 PID: 52 (decimal) / 34 (hex) MPEG
Audio2 PID: 53 (decimal) / 35 (hex) MPEG
Audio3 PID: 54 (decimal) / 36 (hex) MPEG
Audio4 PID: 55 (decimal) / 37 (hex) Dolby AC-3 2.0/5.1
Closed Captions: 608 & 708
2. Standard Definition Service: MPEG Service # 11
Video PID: 177 (decimal) / B1 (hex) MPEG-2
Audio1 PID: 180 (decimal) / B4 (hex) MPEG
Audio2 PID: 181 (decimal) / B5 (hex) MPEG
Audio3 PID: 182 (decimal) / B6 (hex) MPEG
For additional assistance call: 877.727.4144, or send email to: backyardfeeds@pbs.org.
About PBS
CONTACT:
August, 2010
