Hi to all and thanks in advance for any help sent my way. I recently purchased a new 9200HD (my 3rd set), and is acting up right out of the box..The S2 channels are stable but the S channels are having a bunch of problems on the video end..jumping and vertical lines and general havoc..The channel menu screen also jumps and jitters around... So I loaded the firmware from an older set that I bought around 2008 and the picture settles down, but it is still glitching a bit, and the menu is still jumping around... but it is better..
I went to Pansat and also downloaded the latest firmware they have to offer, and that is the same firmware that came with the set... So I dug out a very old set (2006) and loaded the firmware from that set to the new set, and everything works just fine EXCEPT this oldest firmware does not offer S2 on the setup menu, and so none of the S2 channels work but the S channels all work fine and the menu is fine..
So, have any of you folks had this problem, if so what is the solution, and also is there a link to a site that has all of the 9200HD firmware releases where I could get all of the older ones and try them one at a time until this is solved?
Thanks for your help, HB
