Moman19 said:
Bryan,
So what could be different about our two systems? That's the million dollar question and shouldn't be too difficult to determine. Maybe the engineers at Dish will read this ansd ask use for particulars. I'll gladly tell all.
As far as I can tell, I'm not doing anything out-of-the-ordinary to cause the daily BSODs. Just an 811 tied to an Dish 500 and OTA antenna with 90% signal strength.
First off, this root cause could be anything and it may not be related to a difference in configuration. There is a Poll thread I started to capture peoples experience in hopes to try and narrow it down.
The root cause could be anything from how you go about using your remote to the information contained within specific OTA streams. It is a lot more difficult to figure your question than one may think. The issue could be a component within the 811. Perhaps a slight difference in a vendor chip.
I don't think anyone is doing anything out of the ordinary. I currently have my OTA for most channels around 60-70%. IT dropped when I added a second receiver to the OTA. I removed my Pre-amp and also remove attuentor. Funny thing is that my signal strength got stronger when I remove the pre-amp. This little excercise showed me how fragile OTA can be and how it is an art at times.
I degress...
Well last night I think I saw the channel change reboot for the first time. I am not sure if it is related to the drop in signal strength, but I did not get it to happen before this topology change.
I would suggest reading the poll thread on this issue and add your experiences there.
My gut feeling is that the issue is more related to the mix of OTA channels you have. Would be interesting data point to find two people in the same area and see if they are having similar experiences. At this point, the issue is anybodies guess but figuring out what use case differences we have between one and another is not a trivial task.
Are all your channels showing 90% with little fluctuation?
