Hi, this post may be redundant, but I'm sorry, I've already waded through posts for about 15 minutes, and haven't found a thread that deals with my problem, or if there is one, I haven't found it. So I apologize ahead of time. Also, I'm competent enough to connect coaxial cable, but as for the other tech stuff...dunno.
We turned off the cable, but still desire to watch over the air tv. I bought an "Amplified, indoor/outdoor HDTV Antenna" from radio shack. Since we used to subscribe to dish, I figured I could used the same co-ax wire to attach the antenna to the digital converter. I got up on the roof, attached the HDTV antenna, unplugged the dish wires from the pointer, and plugged one of the 2 wires to my antenna. I followed the wire down off the roof, and saw where the junction was. The 2 wires went into a 4 pronged, co-ax connector thing. One of the 4 connections went to the single co-ax wire that went into my house.
I plugged that connection into the digital stream converter, which goes into my TV. However, when I change my TV inputs to the "antenna", I get "NO SIGNAL".
Any help would be greatly appreciated.
Tech Specs of the HDTV Antenna...
impedance 75ohms
Frequency range...
VHF47-230MHZ
UHF470-890MHZ
average gain of amp: 20dB
return loss 6dB
noise figure: 4dB
I have no idea what any of that stuff means.
impedance 75ohms
Frequency range...
VHF47-230MHZ
UHF470-890MHZ
return loss 6dB
noise figure: 4dB
