I have a local PBS channel through my OTA antenna that the signal comes and goes. At times I will have 80 to 85 signal strength for an hour or two. Suddenly the signal strength will drop to 0 to 5 and remain like that for a few hours. Then the signal will come back to full strength again.
What are the possible causes for this type of intermittent signal? Is this a station issue?
I have a winegard antenna that has the coax diplexed into the sat coax on the roof and then diplexed back out at my HD10-250. I tried running directly into my TV receiver and had the same problem so I ruled out my DVR as the issue.
I will try running a coax direct from antenna to dvr but I don't think that is the problem.
Any ideas would be appreciated.
