I have finally mounted the largest VHF antenna that will fit in my attic and as high up as I can get it. I'm able to get everything ITC except for the target, the ever elusive KCWY13 in Casper, WY. I can see the transmitter antenna with a direct LOS. Problem is the power output is so low and directional, I'm barely able to pick up the back side lobe of the signal.
To compound the problem, I also know that the AGC on the amplifier is pretty lame. The signal strength varies from 20+ to 65+ on my HDTV signal strength meter.
So the question I have is will any antenna amplifier help push the low end signal up high enough to keep the signal above the digital clip?
My cable is only about 20 feet long between the antenna and TV. So, what if anything, will push the signal from the 20s up to the 60s and keep it there?
