I have been having problems with my system for a week or two. It seems to come and go. Yesterday it got worse and just to check I replaced my expensive Norsat 8115 with an old Cal-Amp Mag 90 that I had in the junk box. It seems to have cured the problem, but I will watch it for a few days just to make sure.
The only thing I have been able to figure is that the Norsat was going into oscillation for some reason. But that is just a guess. The symptoms were that it would be fine with good Q then the Q would drop sharply and then come back up. I also noticed that the S would drop for a split second at the same time.
I was thinking of buying a second 8115 for my dual LNB feedhorn but that's a lot of money for 6 mos use, which is about how long I have been using this Norsat.
Could this be a power supply intermittent failure in the 922?
Is there any cure for this or is the lnb just scrap?
Can it be sent somewhere to get fixed?
Is there number for Norsat?
