I have an OS Mio 4k+ currently using TNAP 4.0 I fell asleep watching TV last night and woke up early this morning to a green screen. The screen reads
We are really sorry. Your STB encountered a software problem and needs to be restarted.
Please send the logfile/tmp/enigma2_crash.log to the OpenPLi forum.
Your STB restarts in 10 seconds!
Component: Enigma2
Close failed in the file object destructor: IOError: [Errno 22] Invalid argument
Component: Enigma2
It stays on this green screen for about ten seconds and then goes to the TNAP 4.0 Starting Enigma2 screen. It stays on the Starting Enigma2 screen for about the same amount of time and then back to the same green screen. It is a continual cycle.
I ended up unplugging the box when I had to leave for work this morning because I could get no response from pushing any of the buttons on the remote or the box itself. When I returned home, I plugged the power back in. The black Edision screen came up as normal, then the TNAP version 4.0 booting screen, followed by the starting Enigma2 screen. It did come on and actually play the channel I was on last night for about 10-15 seconds. After this it went to a Green screen with way to much on it for me to read in the short amount of time it was up. Then it went to the green screen I first mentioned and started the unending cycle again.
I have no idea what I should do or how I should proceed with trying to solve the issue. Any ideas or guidance would be greatly appreciated. I will likely be slow to respond as I am currently working 15 hour shifts at work, but as I said any help will be greatly appreciated. Thanks.
Component: Enigma2
Component: Enigma2
