Hi everyone,
I have got my 10' Perfect Ten dish aligned fairly well now. I am tracking from 22w to 135w for c-band and ku-band (some ku issues on certain birds, but I'll probably get a 1.2m dish for ku anyway). I'm currently using a dual C/KU-band LNBF on the dish.
I am able to receive circular polarized signals such as those on 40.5w, 27.5w, 24.5w, and 22w, if I put the dielectric plate into the LNBF throat.
However, I would like to be able to add another C-band LNBF, or get some sort of setup so that I don't have to go out to the dish and insert/remove the dielectric plate every time I want to change from circular/linear or back again.
For starters I tried put a second LNBF offset from the first one using tie wraps. I attached a scalar to a second C-band LNBF, and then tried to simply place it offset of the current LNBF (above and to the left if facing the front of the dish). I used my SH-200 meter and moved the 2nd LNBF around until I found the best position. It seems to partially work, however I need to tune it more since I'm only getting the Left (Horizontal) signals, and it's definitely weaker. It is a pain to get it to tune, and in turn to tie it down with zip ties with the angles involved.
Also, I'm not really sure I should be placing it where I am. I have the dish pointed at 45w, and am trying to pick up 40.5w with the second LNBF. It seems that I need to put it higher and to the left, when facing the dish, but I would like confirmation of this from someone who knows.
I'll probably try to take two LNBF with scalar rings and do something similar to this next (only using LNBFs instead of the older-style feeds):
http://www.satelliteguys.us/threads/193463-C-band-Linear-Circular-Orthomode-Feed-Modification
Anyway, my question is, are there any other options for having reliable c-band linear and c-band circular on a single dish without having to manually insert/remove a dielectric plate? I don't know a lot about the older style feeds, but I'm wondering if there is any option for a feedhorn that would allow for both linear and circular (both H & V, of course)?
sgs
sgs
