OPENBOX S9 HD
The specs show it has a wide range of input freq and voltage. So even if your 92vac has large overshoots it probably will run on it. I haven't seen a power pack pictured or mentioned so it probably will not work on direct 12v.
POWER
AC auto input range:100-240VAC 50/60Hz
Consumption (Standby): Max. 10W (<1 W)
Jim
Thanks for the info... I wish it said 90-240 VAC ;) The 2 that do not work right say 100-240. The others that do, and I can get to, show 90 volts at the lower limit. The "switching" power supplies usually handle the inverter quite well, the straight regulated often have problems.
When budget allows, I tythink I will try one!
Hi friends,
I have bought a Openbox S9 HD from Dex-shop. It seems like a good receiver but when i will watch the channels, i get the message''scrambled''. What can i do? Thanks in advance.
Gurel
"Scrambled " means you are tuned to a channel that requires a subscription. You'll need to do some research and find if there are free channels on the satellite you are aimed at, or find another satellite, that has free channels. You MAY be able to buy a subscription card for the Openbox for certain channels locally. I'm in Michigan, USA and we don't have that capability here, but in Europe it is common. Welcome to SatGuys.
Recording on the S9 Help
NBC MUX no signal this AM
