Hardrive is a 320 GB Western Digital that has been partitioned into 2 ~150 GB partitions. After connecting the hardrive, OpenBox kept re-booting itself. Had to shut off the receiver and remove the drive. Had this issue for sometime, got a new firmware from Gosatellite.com tech that did not help (will post the version later when I figure it out).
Have better results using a USB flash drive, 16GB. The problem is the receiver stops recording although plenty of space is free. When checked the menu options, the ones for USB are dimmed out. For some reason the receiver stops seeing the drive, then I have to remove the USB and insert it back in. Then I can record again. Thank you.
