Hi to all!
Just purchased the OpenBox S10, the Vbox 7 & the BSC621 which I should receive by the end of next week.
I’ve been reading through the online manuals for each which leads me to ask questions from other users on this forum.
Old setup: Toshiba TRX2220 analog receiver & dish mover with a Satcruiser DSR 101 slaved to it with a 7 ½ ft dish. Horizon to horizon: 72 degrees west to 137 degrees west is what I can receive here in Western New York. Have no reception problems with C or Ku band. The wiring running in from the outside consists of 4 cables: C band, Ku band, Actuator control, & Polorator control.
If my understanding is correct: the BSC621 will do all the switching so I just have to connect the loop cable from the Ku connection to the Lnb port & then connect the recv out port to the C band line which would then be hooked up to the Vbox 7. I would then cap off the old Ku line at the dish.
Is this correct?
Vbox 7 connections: I traced down all the wires on the back of the Toshiba: I know which ones the M1 & M2 are & ground (actuator feed back line) & actuator return pulse wires. There is also a + 5v wire: the manual states this the actuator signal line that provides + 5v to a hall effect device. ( no idea what that is!). The Vbox 7 has two connections for the Reed Sensor. Which holes do the Pulse & ground wires hook into. From the manual & pictures online I don’t see any markings as to which one is which. The M1 & M2 connections are clearly marked.
Do I still need the +5v connection & if so where do I connect it?
Which hole is for the pulse connection & which one is for the ground on the Vbox 7?
How to start out? These are assumptions on my part, that’s why I’m asking for suggestions from current users.
(1). Setup limits on the Vbox 7.
(2). OpenBox S10: do I go into the Satellite list first and select all the Satellites that I should be able to receive or do I go into the Antenna setup first?
(3). BSC621: according to forum post the settings for C/Ku on a single antenna setting menu are:
LNB Type: universal
First (low): 5150
Second (high): 10750
22kHz: off
DiesqC: off
Do I set this up once or does have to be set for each satellite individually?
What about motor settings? With the above settings what should the motor settings be set at & again is this a one time selection or do I have to do this on a satellite by satellite basis?
Any suggestions will be appreciated! I’m looking forward to making my BUD useful again!
Thank’s for taking the time to read this long post.
Ranger One
Is this correct?
LNB Type: universal
First (low): 5150
22kHz: off
DiesqC: off
Ranger One
