I have a RV in Erie, PA and have aVIP211K HD Solo receiver. We have a Dish 500 Satellite. Both of the satellites...110 and 119 are getting very good strength....at least 65. but we are only picking up the lower channels. The channels on the 119 I think are the ones that we are not receiving. We have been told by Dish that the satellite is not pointed in the right direction but how can you get good strength showing on both satellites and that happen. I also had a tech tell me that I should change the lnb to a Dish Pro Plus Twin that it would pick the stations up. Does anyone out there have any ideas. Also, when my husband took the lnb loose there was only one wire attached to the 119 marking and he changed it to the other one to see if that would change and it did not. Should there be two wires. We used this same system with our previous receiver and picked up all of the channels..it has only changed since we got this new receiver. Do lnbs go bad and be able to view only part of the channels. I know I have asked a lot of questions but hopefully someone can help. Thanks in advance.
