Yes, it must be "brain dead Monday." I should have seen that.You are on "EARC" AKA Eastern Arc then.
As stated it must have been a big, thick, dark, and bad cloud to the South. Time will tell as time goes by.
RT.
(and no tree problem)
But in the end ALL satellite fails at a certain rain strength, but comes back when the rains settles down to a steady slower rate. Unless you have a huge 1 meter sat dish, you will lose your signal if it rains really hard . Even when I had Directv it would lose signal as soon as the clouds gathered over head and Before the rain even started falling. With DISH it happens once the rain becomes strong and returns once the rain settles to a slower rate. It is part of doing business with satellite. Now if rain fade is such an issue for you , I suggest returning to cable or stick strictly with ota only , or get a huge sat dish that cuts rain fade to 0.
Well apparently I have alot to learn about Dish. Twelve years with DirecTv, will be switching in the week or two to Dish H/J system. A SS of 64 is usually not very good with DTV. I live about 40 miles north of Houston in a heavily wooded area. It is currently pouring down raining as I write this from my phone, we still have a Satelite signal. My SS is usually around 92-94. Had construction going on one time at the house and had to move the Satelite dish for a temporary spot for a while. The SS was a 86 in the new temp location, as the spring season approached and the trees started budding out, my SS went to 58-60. To say the least we lost signal on every spit of rain & 5 mph wind blowing the trees. The signal would freeze up in perfect sunning weather. We moved back to the original spot after construction, SS went back 92-94 and all is good again. I need to learn more about the Satelites and thier locations and the SS for my new Dish H/J system.
Sat 110
TP 14 15 16 21
63 67 64 64
Sat 119
TP 14 15 16 21
59 70 71 73
Sat 129
TP 19 20 29 30
48 48 49 48
Sat 61.5
TP 10 14 29 31
44 50 55 45
Sat 72.7
TP 15 17 19 21
52 50 52 50
Sat 77
TP 13 16 20 21
34 34 36 38
