Got Several questions about the setup of the 942:
1: Do you have to run 2 separate RG6 cables from switch to each sat inputs on the receiver? The reason I ask this is because in the box there was a 2-way splitter and 2 small RG6 cables. On page 112 of the users guide there is a picture of the the splitter connected to sat and them split out to sat input 1 & 2 on the receiver. I tried this and got a failure on check switch. Had connect straight from swith to input 1..
2: On the TV2 output will you be able to see all sat channels on the 2 TV? Will you get the guide? The reason I ask this because on the receiver it says TV2 channels 2-69
I was able to get the receiver up and running but wanted know if I understand everything correctly before I ran another cable.
