This is what I have...
I had Voom installed last week and it has the following version installed:
Secure Firmware Version: V16
Current Software Version: V00.01.04
HAL Version: 00.06.00
Middleware Version: 00.01.36 (was 00.01.06 yesterday i think)
Guide Version: 00.19.8E
I have the following issues with this software:
1) I can not receive my local NBC channel. The channel shows up in the guide correctly, but when tuned to it either shows the last channel viewed or shows a blank screen. I believe it has something to do with my local NBC being on digital channel 36.
1a) This is still happening.
2) I get audio drops when tuning to channels sometimes and have to change the channel and then go back to get the audio.
2a) Haven't seen today but can't be sure that it is not still happening.
3) The picture that is displayed on SD channels is shifted to the right quite a bit. The guide overlay is not shifted at all. You can also see this shift in the guide display. The picture in guide (PIG) is shifted in its space the same as the normal picture is shifted. I can not make adjustments to the TV since any changes will also affect the position of the guide which is centered perfectly. I see this on two different Voom boxes on two different TV's (Mitsubishi 65" WS rear projection, & Philips 17" WS LCD flat panel).
3a) Today the picture appears to be correctly positioned on SD channels but it is shifted slightly to the left on non HD premium channels on my Philips 17" WS LCD flat panel. Mitsubishi looks ok probably because the overscan is wider. Why can't they just get this right? Was this change due to the middleware change or did they change something in the way they are broadcasting the signal?
4) Just started seeing last night white spots on the screen. Could only make them go away by shutting off box and restarting.
4a) Haven't seen today but can't be sure that it is not still happening.
5) WB was coming in strong when I got the box with a signal strength of about 98. Now it runs from about 80-95 and gets very pixely if that is a word. May not be a software issue, but all other OTA channels are coming in strong still.
6) And on another topic, no USA channel (The 4400) and no Sci-Fi (SG1, SG Atlantis, Farscape, Battlestar Galactica, etc.)
What happens in the next month will determine if I remain a Voom customer or not.
Just my $79.90 + tax, title, and licensing charges worth,
jbcaro
jbcaro
