Help needed
I have worked all day to set up the system
Pansat 2500/SG2100 DiSEqC Motor/WINEGARD 76cm KU band OffSet Stell dish/ASC321-2 Universal Digital Ready Ku LNBFs
My latitude is 40.0247 north and longitude -83.0639 west
the pole perfectly plumb and level mast and all angels are set as said in the manuals. I picked up Nimiq2 as my south most sat and pointed my dish toward that direction, entered my latitude and longitude in USALS in my receiver, siganl was 69% but quality was 0, I tried serveal other sats even used the smart search no luck at all. WHAT COULD BE WRONG. here are my questions
(1) Is Nimiq2 right south most sat and then what transpond is active
(2) I was trying to point the dish toward Nimiq2, the compass was crazy and not pointing the same direction consistently and I was not sure which direction was true to Nimiq2. Any idea how to fix the crazy compass
(3)when I set 23.7 degrees as "Dish Bracket Angle", I could not find a clear marker marking this angle and that thick nut cover at least 15 degrees on Dish Bracket Angle slide ( you know what I am talking about). what mark would you use to set this angle or this is not that important
(4) I might mess up and want try it all over again, how can I drive the motor back to zero
Thank you for help
guo248
Thank you for help
guo248
