I recently had a Vip222k installed in my house. I planned on adding another tv but only had my main tv (connected via hdmi) when the reciever was installed. The installer told me that adding the second tv would be simple -- run coax from the reciever's home distribution output directly to the second tv, access the modulator settings, set the output to air ch 60 and run auto setup on the second tv. So a couple days later I did exactly that... I ran a new 50' coax cable from the receiver up the wall, through the attic and down the wall in the other room directly into the second tv.
...well I can't get the second tv to show anything... i have tried switching the modulator channel (on both air and cable settings) and running autoprogram several times with no luck. Even if i manually tune the tv to the channel i select in the modulator menu, I get nothing... The tv is a fairly new lcd panel with a digital tuner.
I have a feeling that I'm missing something really simple. Any help is appreciated!
