SimpleSimon said:but by this time, you probably have the experience to do it - assuming you understand what the "skew" actually is for. If not, let us know and someone will explain it.
I'd appreciate an explanation of what skew is for, thanks.
Since my mast wasn't installed vertical anyway after I tweaked the elevation and horizontal movements for maximum signal, and I did also adjust the skew.
I pretty much just watched the signal strength on the sat finder and tried to set all of them up so that any movment in any direction results in the signal getting weaker. This way it would seem things would be in the middle of the strongest signal.
If there is a strategy thats preferable to whats in the 811 manual for Dish alignment I'd love to hear that also.
I'm probably going to order a 3ghz ground block and barrel connectors and realign the dish from scratch. I know it probably won't improve things much if any but it will be a learning experience for when friends or I have problems in the future.
Thanks again for any/all advice.
