No Local Channels?
Ok GOT IT.... i HAVE A DUAL LNB RIGHT HERE. SO I GO FROM THE DUAL LNB TO THE INPUT ON THE TWINDPP AND HOSECLAMP IT JUST AS IN THE PICTURE YOU SENT CORRECT? dOES IT MATTER IF IT IS ON THE LEFT OR RIGHT SIDE OF THE TWINDPP
does it say "DP" on it? for DishPro
yes you just plug it into the imput port on the Twin you have and hoseclamp it
it goes as shown in the picture...so if you are behind the dish looking at it (as it shows in the pic) its to the LEFT...that would be 129. When using multiple satellites they get set up opposite of how they are in the sky (due to the bounce off the dish)
tHANKS FOR ALL THE INFO AND TIME....... iLL LET YOU KNOW HOW IT GOES! i SEE THE LOGIC IN IT AND IT SHOULD WORK FOR ME... MY LNB SAYS - DUAL LNB - mODEL ZKF-G52N - INPUT FREQ. 12.2 - 12.7 GHz. WILL THIS DO IT?
does it have a DP on the cover of the LNB? It does need to be dishpro
No it doesn't but I can get a dishpro dual LNB from a friend...... I have the pics you sent and the instructions, I'll get the dishpro dual LNB or Single LNB from my buddy and do as you instructed. Again thanks so much.... Your help is appreciated and I'll let you know how it goes in a day or two.
TV2 002 error on 322 receiver
Is anyone else losing signal on 61.5?
