no channels
pagej5
I've just recently purchased a coolsat 4000 pro fta receiver and tried to install it,but I haven't been able to receive any channels,,,I have a 76cm winegard dich mounted onto a sg-2100 H-H motor with a snh-031 lnbf...signal level is 70-80 on most satellites,,, but quality level is low...all that I get when trying to view a picture is the menu screen, when I try to veiw a picture it says no channels ,,My area code is 23024....appreciate any help!!!
Code:
                      Bumpass, VA 23024
          Latitude 37° 53.904'N Longitude 77° 47.796'W
                        Sat Name Sat Lng Az(t) Az(m)   El  Skew
                    Intelsat 901   18.0W 109.7 120.4 15.0 -48.0
                    Intelsat 603   20.0W 111.2 121.8 16.5 -47.4
                           NSS 7   22.0W 112.7 123.3 18.1 -46.7
                    Intelsat 905   24.5W 114.6 125.3 20.0 -45.8
                    Intelsat 907   27.5W 117.0 127.7 22.2 -44.7
                  Hispasat 1C/1D   30.0W 119.1 129.8 24.1 -43.6
                    Intelsat 801   31.5W 120.4 131.1 25.2 -42.9
                    Intelsat 903   34.5W 123.1 133.8 27.3 -41.4
             AMC 12 & Telstar 11   37.5W 125.9 136.6 29.4 -39.7
                         NSS 806   40.5W 128.9 139.6 31.5 -37.9
                       PAS 6B/3R   43.0W 131.5 142.2 33.1 -36.2
                          PAS 1R   45.0W 133.6 144.3 34.4 -34.8
                    Intelsat 705   50.0W 139.4 150.0 37.4 -30.9
                    Intelsat 707   53.0W 143.1 153.7 39.0 -28.3
                    Intelsat 805   55.5W 146.3 157.0 40.3 -26.0
                           PAS 9   58.0W 149.6 160.3 41.4 -23.5
                        Amazonas   61.0W 153.8 164.5 42.7 -20.4
          EchoStar 3 & Rainbow 1   61.5W 154.5 165.2 42.9 -19.8
                Estrela do Sul 1   63.0W 156.7 167.4 43.4 -18.2
                    Brasilsat B2   65.0W 159.7 170.4 44.1 -15.9
                    Brasilsat B1   70.0W 167.4 178.1 45.3  -9.9
                Nahuel 1 & AMC 6   72.0W 170.6 181.3 45.7  -7.4
                       DirecTV 5   72.5W 171.4 182.1 45.7  -6.8
                           SBS 6   74.0W 173.8 184.5 45.9  -4.9
                           AMC 5   79.0W 182.0 192.6 46.1   1.5
                         Nimiq 2   82.0W 186.8 197.5 45.9   5.4
                           AMC 9   83.0W 188.4 199.1 45.7   6.6
                    Brasilsat B3   84.0W 190.0 200.7 45.6   7.9
                          AMC 16   85.0W 191.6 202.3 45.4   9.2
                           AMC 3   87.0W 194.8 205.5 45.0  11.6
             Intelsat Americas 8   89.0W 197.9 208.5 44.5  14.0
                Galaxy 11/Nimiq1   91.0W 200.9 211.6 43.9  16.4
                    Brasilsat B4   92.0W 202.4 213.1 43.6  17.5
                       Telstar 6   93.0W 203.9 214.5 43.3  18.6
                       Galaxy 3C   95.0W 206.8 217.4 42.5  20.8
             Intelsat Americas 5   97.0W 209.6 220.2 41.7  22.9
                       Galaxy 4R   99.0W 212.3 223.0 40.8  24.9
                           AMC 4  101.0W 214.9 225.6 39.8  26.8
                           AMC 1  103.0W 217.5 228.1 38.8  28.7
                          AMC 15  105.0W 219.9 230.6 37.7  30.4
                         Anik F1  107.3W 222.7 233.3 36.4  32.3
        DirecTV 6 & EchoStar 6/8  110.0W 225.7 236.4 34.8  34.4
                         Anik F2  111.1W 226.9 237.6 34.1  35.2
                   Solidaridad 2  113.0W 229.0 239.6 32.8  36.5
                        SatMex 5  116.8W 232.8 243.5 30.3  39.0
         EchoStar 7 & DirecTV 7S  119.0W 234.9 245.6 28.8  40.2
 EchoStar 9/Intelsat Americas 13  121.0W 236.8 247.5 27.4  41.3
                      Galaxy 10R  123.0W 238.6 249.3 26.0  42.4
                       Galaxy 12  125.0W 240.4 251.0 24.5  43.3
            Galaxy 13/Horizons 1  127.0W 242.1 252.7 23.0  44.2
             Intelsat Americas 7  129.0W 243.7 254.4 21.5  45.0
                          AMC 11  131.0W 245.3 256.0 20.0  45.8
                       Galaxy 1R  133.0W 246.9 257.6 18.5  46.5
                          AMC 10  135.0W 248.4 259.1 17.0  47.2
                           AMC 7  137.0W 249.9 260.6 15.4  47.8
                           AMC 8  139.0W 251.3 262.0 13.9  48.4
                    EchoStar 1/2  148.0W 257.5 268.2  6.9  50.4
        Satellite Finder is (c) Copyright 2004, P. Lutus
I would remove the motor and try to find and store a few satellites before adding it. When you do add it AMC-5 seems to be the closest to True south for you, its at 79w.
The motor elevation should be at 52 deg. (one side of the motor is elevation and the other is latitude. so watchout for that)
And the dish elevation at 24 deg.
Make sure you have the correct L.O. setting for the universal LNBF you have it should be set to Universal 09750-10600 as the L.O.
Fox Nfl Feeds on Intelsat Americas 6?
36" X 38" Primestar problem
