With the newer Dish Pro Plus LNB's, is their still a need for the DPP Separator? Specifically for the ViP 612?
There is not, and never will be, an LNB that will eliminate the need for a separator, if you are using a receiver that needs one (any receiver with 2 satellite inputs). The hopper basically has the separator built in, that is why it does not need one, has nothing to do with the LNB/Node
Edit* I should say, you can run 2 lines to the receiver and not need a separator, but you will always need a line to both ports. The exception is a 311K and a 512. They are converted 322 and 522/625 respectively, which have 2 sat. inputs, but you only run a single cable to 1 sat in port, the 2nd tuner & port has been deactivated.
Completely irrelevant in this conversation as we are talking about Dish not DirecTV.Unless you have a directv SWM SYSTEM
Dish could license the technology
I believe directv is using SWM under a licensing agreement.
First it would eliminate all the unnecessary wiring on a new installation and eliminate the need for super joeys as they could ship the extra tuners with the hopper.
My sister has a 512 connected to a separator, so the 2nd tuner is definitely not deactivated, just the TV2 outputs.There is not, and never will be, an LNB that will eliminate the need for a separator, if you are using a receiver that needs one (any receiver with 2 satellite inputs). The hopper basically has the separator built in, that is why it does not need one, has nothing to do with the LNB/Node
That is correct, I was thinking there was a 2nd receiver that disables the 2nd tuner, like the 311k, but maybe not.My sister has a 512 connected to a separator, so the 2nd tuner is definitely not deactivated, just the TV2 outputs.
