hold on!
WHEN your dish is pointed to your TRUE South satellite, you set the LNBF accordingly.
You can tweak it a little later if need be, but it's basically not moved clockwise nor counterclockwise more than 10°.
The motor and dish mount cause the dish to skew (twist on bore-site to the satellite) as it moves.
WHERE you twist that LNBF to, is dependent upon which brand / model you bought.
I consulted the Sadoun site, and I -think- you have a DMX-741.
Normally, you would twist the LNBF 'till the mark on the body (the cylinder) was at 12 o'clock, but due to manufacturing mistakes, some brands may need to be set to 3 o'clock.
All of a given model/brand will be off, so there's nothing to worry about, but sometimes that info is a bit hard to come by.
Below is the standard answer I give to people wanting to know how to twist their LNBF.
It may not be all inclusive, but I think it covers this situation.
If your H and V transponders are reversed (interchanged) you need to twist the LNBF by 90°
Twisting 180° is the same as not twisting it at all...
SO, setting the mark to 12 or 6 o'clock is the same.
Likewise, setting it to either 3 or 9 o'clock is the same.
edit:
That mark on the scalar you highlighted, has NO MEANING... so disregard it.
Anole pix of skew for CK-1 and BSC-621 LNBf's
SatelliteGuys.US - View Single Post - Quick - Help me think this through! Geosat Pro C/Ku
[09:19] <Anole> Fred - how do you orient the DMX741 at TS ?
[09:19] <Linuxman> you can put the 0 line at either north or south
[09:20] <Linuxman> it has a plus or minus 10 degrees off center if i remember correctly
Iceberg and skew of C2:
http://www.satelliteguys.us/free-air-fta-discussion/186011-setup-geosat-pro-c2.html#post1939026
edit:
