I ran the cable directly to LNBF 2, and was getting no signal, so I connected to LNBF1, and started getting a signal. I am not sure what the problem is. I must admit the dish seems a little loose on the pole, despite using Quickrete to make the pole steady in the ground. One of the bolts associated with elevation also broke. On channel 106 the signal quality reading is: S: 70 Q: 60, channel 113: S: 40 Q: 0, Channel 901: S: 55, Q: 65. I am going to go ahead and get some RG6 cable, a METER - SATELLITE FINDER - SIGNALCAT, and a INSTALL PARTS - GEOSATPRO DELUXE SUPPLIES kit from GloryStar. i am hoping all of that will fix the problems I am having.
BTW, is it OK for me to run the cable through a surge protector/circuit breaker power strip before connecting to the receiver? if not, I'll disconnect it, and run a cable from the wall jack directly to the receiver. Thanks.
