Ok, it looks like this receiver is about as flaky as the CNX Mini I have!
Sometimes my motor will move to a satellite, let's say Hispansat 30W and sometimes it will go there and stay with no issues. Sometimes I move over to it will go then go back to E*119 or sometimes I have seen it go back to Nimiq 2 my true south! It is running the
Factory Firmware since I bought it and I recently upgraded it to the
latest firmware and it seemed to fix it but still it does quirky things I don't like! Another thing I hate with the CNX is that it
NEVER remembers what LNB settings between linear and circular! Go to NASA and have to change it every time by hand, it sees all linear settings fine.
Very frustrating!
As I stated in my posts on helping you was to the letter on Normal Setups out of the box and Normal I mean, what works with most of the boxes when you get them and what we all use for settings for flawless use and setup. One reason I mentioned for help from someone else that has and Elite to chime in and give ya some help or pointers.
It seems like there are issues with using USALS with this box as posted by
AcWxRadar!
Thanks Radar for the help there! I assume you are using the
latest Factory Firmware? If not give that a go. Might want to try past
Firmware Versions if you can find them by the
Factory, sometimes you will find one that works as well or better than the latest!!
So with that, use
DiSEqC 1.2 for the positioning command and see how that goes. I would until you figure out the problem 100% just take the switch out completely and use whatever LNB you need for getting your true south bird going straight to the motor. Still may be a bad switch so eliminate the possible problem there by just going direct to the LNB to the motor for TRUE SOUTH!
***Tip if you are going to try DiSEqC 1.2***
Start off by doing a fresh
Factory reset of the Elite and working with a new STB! This always works as a last resort for me!
Moving to the motor does not have a brain; it has memory for
DiSEqC 1.2 so I guess it kind of does! If it is able to store and recall to the motor using
DiSEqC 1.2, then sure it does have a brain.
If you use DiSEqC 1.2, then the motor will memorize the locations. With that said you can see how if you previously stored positions in you box settings and used
DiSEqC 1.2 at one time you could be working on a vast set of problems for if the motor was set up wrong then positions stored using
DiSEqC 1.2, of course it will move to the wrong positions it was stored too causing problems!
Wrong stored
DiSEqC 1.2 positions and a double strike with the weird working USALS
Firmware on the Elite is going against you, this will be a task!
It is going to be trying many things to see what will work here to find a solution! Don't give up right yet!
In short I would start off fresh by going back to Factory Reset with the Elite, resetting the motor, make sure it is at 0, take the switch out go direct, make sure your settings are correct in the Longitude and Latitude menu, LNB settings are correct, make sure that you are 100% dish wise setup to the letter with elevation/declination settings correct and your able to get good signal and quality
(QUALITY MATTERS NOT SIGNAL) on your True South Bird, use
DiSEqC 1.2 instead of USALS and see if that works for you!
Hope this helps!
Sorry for not understanding your frustration completely for you were going by the letter before, sounds like it is one funny box to work with!
B~Man
