I am new to this forum and have done some reading recently on FTA,
This sounds like a hobby I will be very interested in.
Owned the DirectTV system from SONY when it was new in 90s.
Self install of this system was very easy.
discarded (gave to someone) when moved to location with trees and no way to avoid them.
During testing found a signal from some other satellite which I assume was the Dish system
Switched to cable -then digital cable - now rabbit ears
Anyway there is possibility I am moving again due to my work
and this time I will choose my housing location to be more satellite friendly.
I had some questions about LNBS
There are 3 kinds for FTA correct?
1 DBS
which has a circular polarization (left/right)
2-3 KU linear polarization (Horizontal/Vertical)
this type is split into standard and universal
the difference is the LO for the universal has a wider freq range
and will pick up more stations
Is there a big price difference between these two KU LNBs?
what is a good quality universal unit?
(also how do you measure the quality of a LNB)
Also would a Sony LNB that has the LED which flashes faster when you find a signal help avoid the need of a signal meter.
If so I am looking for another one of these used.
fataf
1 DBS
fataf
