I was able to get my dish today from Fedex a day late by
driving to pick it up myself. oddly the map system drivers use
did not have my address.
Spent a few minutes to figure out how to bolt everything together
(directions were not very clear).
it is either 85 or 90cm in size and came with roof mount.
directions said it was model 85R5 while invoice says 90cm.
has a standard KU .5db LNB inserted on arm.
carried it outside on my patio and set an approx elevation .
connected it as follows using 75 feet of RG6 cable (plus jumper).
twinhan 1020 -> sf 95 -> LNB
after some rotation I heard a loud beep - meter registered 9
I locked the dish in place temporarily.
noticed it was very sensitive to elevation changes - changes made signal disappear.
my signal strength on software was 80 but quality level= 0?
I am not sure if I needed to switch to a circular LNB or
if my program settings were incorrect.
also tried changing the skew (rotation) of LNB and using direct connection to LNB as options.
Software Settings:
Using newest Twinhan DTV program for the software v 2.432
Configuration
Dish: Dish 1
Type: Fixed
LNB Setup: Setup 1
LNB Setup 1 is
Power: On
LNB Type:Custom : 10750, 0
(choices: Normal - Freq 1: 5150 Freq 2: 5750
Universal - Freq 1: 10600 Freq 2: 9750
Custom - your input values)
22Khz Tone: Disable
Tone Burst: Disable
Data Burst: Disable
Diseqc - disable
packed it back inside but
will try again tomorrow when it is daylight and less cold/not raining.
any suggestions welcomed.
thank you
Software Settings:
Configuration
Dish: Dish 1
Type: Fixed
LNB Setup: Setup 1
LNB Setup 1 is
Power: On
22Khz Tone: Disable
Tone Burst: Disable
Data Burst: Disable
Diseqc - disable
thank you
